I'm running "Armbian_5.34.171121_Orangepizeroplus2-h5_Ubuntu_xenial_next_4.13.14.img" on an OrangePi Zero 2+ H5.
Lots of testing was done with the OS installed on and running from the SDCard. I've solved the board's overheating problems by installing a 30 x 30 x 7 mm Heatsink, plus a 50mm USB Powered Centrifugal Blower Fan. At long last the board runs happily at temperatures typically up to about 40 degrees C at light to medium CPU loads, and at around 65 degrees C when the CPU is pushed to 100% utilisation. With this cooling solution, the board has been reliably running PiHole for about two months now. The 50mm fan and the big heat sink are not a very elegant solution, but as there is plenty of room in the case where this board will live, the solution will do for my purposes.
However - onto the problem that I've encountered today. I decided that I should be running the board with the OS installed on the EMMC, and used nand-sata-install to do that. There are no errors generated by nand-sata-install.
Unfortunately, when the board tries to boot from EMMC, the boot process hangs midway through, at the following line:
5.7357391 fuse init (API version 7.26)
I can't look at any error logs etc, as I can't boot the board sufficiently to get to a working command prompt. I did see this same error once yesterday when booting this board from the SDCard, but a simple reboot eliminated the problem. No amount of reboot attempts solves the problem when trying to boot from EMMC. I've also run nand-sata-install repeated times just in case ...... but that has also not had any effect on eliminating this boot error.
Can someone who understands the ARM Boot process provide any information regarding what's actually happening when fuse init appears during boot process. And, does anyone have any ideas regarding how to fix or work around this error?
Many thanks,
RoyG
