wimsop
  1. Fixed with the release of v60, at least for me.
  2. So there's no way to downgrade once you have the broken version? $ sudo apt-get install chromium-browser=58.0.3029.110-0ubuntu0.16.04.1281 E: Version '58.0.3029.110-0ubuntu0.16.04.1281' for 'chromium-browser' was not found Do you have to change apt repositories for that to work?
  3. Yes, I actually reported the problem only after doing a fresh install on another card first. So vanilla Armbian_5.30_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop.img with single updated package as stated above. Sure thing. What logs do you need, specifically? Nothing in syslog or systemd journal though. I'm not aware of any logging done by chromium, but I'm sure you can point me in the right direction there. For the actual error message, see above. Card is a 16GB Sandisk Ultra UHC-I card I took from another SBC. PSU is the old Xunlong 3A one. How so? Apt-get tells me E: Version '58.0.3029.110-0ubuntu0.16.04.1281' for 'chromium-browser' was not found
  4. Using Armbian 5.30 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i Linux orangepipc 3.4.113-sun8i #16 SMP PREEMPT Tue Jun 13 14:15:57 CEST 2017 armv7l armv7l armv7l GNU/Linux Just updated my chromium from the pre-installed version 58.0.3029.110-0ubuntu0.16.04.1281 which worked fine to 59.0.3071.109-0ubuntu0.16.04.1289 which fails to start for some reason. You can see the window open up for a brief moment, then it crashes with the following error: Received signal 4 <unknown> 0000b472df76 #0 0x0000b5381d12 base::debug::StackTrace::StackTrace() #1 0x0000b5381952 base::debug::StackTrace::StackTrace() #2 0x0000b5381ffc <unknown> #3 0x0000b0783270 <unknown> [end of stack trace] Calling _exit(1). Core file will not be generated. Received signal 4 <unknown> 0000b475ff76 #0 0x0000b53b3d12 base::debug::StackTrace::StackTrace() #1 0x0000b53b3952 base::debug::StackTrace::StackTrace() #2 0x0000b53b3ffc <unknown> #3 0x0000b07b5270 <unknown> [end of stack trace] Calling _exit(1). Core file will not be generated.
