dmorse
19 -
Orangepi pc plus mainline kernel locks up after boot.
dmorse replied to dmorse's question in Orange Pi PC Plus
No, I did not do that 90% of what I do with these small arm board might break my system. I'm used to it. -
I have found a solution to this. 1.) mount the SD card on some other linux box 2.) using chroot, uninstall ntp and wpa-suplicant from the SD card 3.) unmount the SD card, and reboot the orangpi using it. 4.) once you have it booted and conencted to a wired network, do an apt-get update and then reinstall wpa-suplicant and ntp You might not need to do both of these packages, but i had a gut feeling it was going to be one of them. -
Just as the title says. I have taken the current version of debian armbian from the archives, flashed this onto a micro sd card and then installed the mainline kernel packages over this. It boots to a login prompt, but after a few seconds the whole system locks up. Does anyone have any idea what coudl cause this?
Incorrect buffer size with the OV5640 (CAM500B) on the nanopi neo air
dmorse replied to dmorse's question in Allwinner sunxi
I've bug a bit further with this. Looks like vb.size gets at in sunxi-vfe/vfe.c in the function buffer prepare. buf->vb.size = dev->buf_byte_size; dev->buf_byte_size is set from the bsp in vidioc_s_fmt_vid_cap dev->buf_byte_size = bsp_isp_set_size(isp_fmt,&size_settings); -
I've also taken a look at vb->bsize, but that has the same value as vb->size as far as I can see, -
I've managed to track this down to this line in videobuf-core.c b->bytesused = vb->size; vb->size seems to the the size of the whole buffer, but the actual buffer used is a bit smaller. I was goign to modify this to use b->bytesused = vb->bytesperline * vb->height; But after adding a printk to my kernel I can see that bytesperline is 0 -
dmorse posted a question in Allwinner sunxi
I've updated to the latest kernel code, rebuilt and I I can now see /dev/video when I call "modprobe ov5640; modprobe vfe_v4l2" after booting into the nanopi. However, when I run the following ffmpeg -re -i /dev/video0 -c:v libx265 -preset ultrafast -x265-params crf=23 -f h264 ./out.mp4 I get the following error error [video4linux2,v4l2 @ 0x1a9a7f0] Dequeued v4l2 buffer contains 40960 bytes, but 38016 were expected. Flags: 0x00000001. The video format is yuv420p, 176x144, so it should be 176*144*1.5 bytes = 38016bytes. However the buffer seems to be slightly larger. I have written a few small c programs of my own and no matter what there seems to be a bit of extra bytes in the buffer. output of dmesg is attached. dmesg.out -
Should have clarified, I can now see the device and I can capture images off it using this program https://github.com/avafinger/cap-v4l2 However I am still having issues when running this one: https://github.com/jacksonliam/mjpg-streamer I've traced the errors through the kernel and I have hit the block of code mentioned above.
Yep, already have twi_used=0 for twi2. Or were you saying to turn it on? Digging around the kernel and putting various debug statements in various places, I have been able to trace it down to this section of the bsp_clie.c file with a switch on frame_info->pix_ch_fmt[ch] inside the for loop case PIX_FMT_YUYV: if(bus_pix_type[ch] == BUS_FMT_YUYV) { fmt_cfg[ch].input_fmt = CSI_RAW; fmt_cfg[ch].output_fmt = (is_buf_itl[ch] == 1)? CSI_FRAME_RAW_8:CSI_FIELD_RAW_8; } else { printk(KERN_CRIT "[DGM] bsp_csi_set_fmt Failed on frame_info->ch_field (PIX_FMT_YUYV) idx: %d; bus_pix_type 0x%x; case 0x%x, bus_info->bus_ch_fmt 0x%x\n", ch, bus_pix_type[ch], PIX_FMT_YUYV, bus_info->bus_ch_fmt[ch]); return -1; } break; Tracing this back up into the vfe.c file, it looks as if frame_info->pix_ch_fmt[ch] is getting set based on a called to pix_fmt_v4l2_to_common() and the bus_pix_type[ch] comes from find_bus_type(), and the value that gets passed into that comes from bus_pix_code_v4l2_to_common() (and has a value of 0x2006, or BUS_FMT_UYVY8_2x8). I've grabbed the vfe.c and the ov5640.c files from the lichee kernel and put those into my armbian source tree before building and that does seem to get me past this issue, but I now have problems when trying to map the memory for the buffers.
This is on a fresh build of Armbian from source. I'm not seeing the camera appearing in /dev/video0, as you would expect. I've tried the solution that @sri suggested on this thread https://forum.armbian.com/index.php?/topic/3225-nanopi-neo-air-cam500b-issue/ but the device is still not visible. Here is the contents of my /etc/modules file #w1-sunxi #w1-gpio #w1-therm sunxi-cir hci_uart rfcomm hidp dhd g_serial ov5640 vfe_v4l2 And here is the output from dmesg [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.113-sun8i (root@crosscompile) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #10 SMP PREEMPT Thu Jul 20 11:40:34 BST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 160 MiB at 56000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 131072 [ 0.000000] free_area_init_node: node 0, pgdat c0a7b900, node_mem_map c0c01000 [ 0.000000] Normal zone: 1152 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 129920 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1093000 s11968 r8192 d12608 u32768 [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920 [ 0.000000] Kernel command line: root=UUID=0f2fc787-984f-4361-a5eb-3c1c9964b243 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=1833f8f9-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 1048576 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 512MB = 512MB total [ 0.000000] Memory: 336300k/336300k available, 187988k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0981220 (9701 kB) [ 0.000000] .init : 0xc0982000 - 0xc09d8ec0 ( 348 kB) [ 0.000000] .data : 0xc09da000 - 0xc0a88fd0 ( 700 kB) [ 0.000000] .bss : 0xc0a89784 - 0xc0c004c0 (1500 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000279] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) [ 0.000304] pid_max: default: 32768 minimum: 301 [ 0.000479] Security Framework initialized [ 0.000541] AppArmor: AppArmor disabled by boot time parameter [ 0.000743] Mount-cache hash table entries: 512 [ 0.001818] Initializing cgroup subsys cpuacct [ 0.001836] Initializing cgroup subsys memory [ 0.001887] Initializing cgroup subsys devices [ 0.001900] Initializing cgroup subsys freezer [ 0.001911] Initializing cgroup subsys blkio [ 0.001935] Initializing cgroup subsys perf_event [ 0.002029] CPU: Testing write buffer coherency: ok [ 0.002087] ftrace: allocating 25333 entries in 75 pages [ 0.030396] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.030417] [sunxi_smp_prepare_cpus] enter [ 0.030469] Setting up static identity map for 0x4066a498 - 0x4066a4f0 [ 0.031611] CPU1: Booted secondary processor [ 0.031611] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.031753] CPU2: Booted secondary processor [ 0.031753] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.040575] CPU3: Booted secondary processor [ 0.040575] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040697] Brought up 4 CPUs [ 0.040697] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.041022] devtmpfs: initialized [ 0.052069] wakeup src cnt is : 2. [ 0.052081] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.052092] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 [ 0.052103] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.052115] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.052125] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 [ 0.052136] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.052148] sunxi pm init [ 0.052304] pinctrl core: initialized pinctrl subsystem [ 0.059242] NET: Registered protocol family 16 [ 0.062179] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.062275] script_sysfs_init success [ 0.062305] sunxi_dump_init success [ 0.063295] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.064509] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.064509] plat: add bmp085 device [ 0.064509] plat: add pcf8591 device [ 0.064509] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.064509] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.064509] script config pll_video to 297 Mhz [ 0.064509] script config pll_de to 864 Mhz [ 0.064509] script config pll_ve to 402 Mhz [ 0.064509] sunxi_default_clk_init [ 0.064509] try to set pll6ahb1 to 200000000 [ 0.064509] try to set ahb clk source to pll6ahb1 [ 0.064509] set ahb clk source to pll6ahb1 [ 0.064509] try to set ahb1 to 200000000 [ 0.064509] try to set apb1 to 100000000 [ 0.070263] bio: create slab <bio-0> at 0 [ 0.070342] [ARISC] :sunxi-arisc driver v1.04 [ 0.093850] [ARISC] :arisc version: [v0.1.58] [ 0.200700] [ARISC] :sunxi-arisc driver v1.04 startup succeeded [ 0.202460] SCSI subsystem initialized [ 0.202460] usbcore: registered new interface driver usbfs [ 0.202460] usbcore: registered new interface driver hub [ 0.202460] usbcore: registered new device driver usb [ 0.202460] twi_chan_cfg()340 - [twi0] has no twi_regulator. [ 0.202460] twi_chan_cfg()340 - [twi1] has no twi_regulator. [ 0.202460] twi_chan_cfg()340 - [twi2] has no twi_regulator. [ 0.202460] Linux video capture interface: v2.00 [ 0.202460] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.202460] cfg80211: Calling CRDA to update world regulatory domain [ 0.202460] NetLabel: Initializing [ 0.202460] NetLabel: domain hash size = 128 [ 0.202460] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.202460] NetLabel: unlabeled traffic allowed by default [ 0.202460] Switching to clocksource arch_sys_counter [ 0.214858] FS-Cache: Loaded [ 0.215224] CacheFiles: Loaded [ 0.227056] NET: Registered protocol family 2 [ 0.238355] IP route cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.238993] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.239243] TCP bind hash table entries: 16384 (order: 5, 196608 bytes) [ 0.239517] TCP: Hash tables configured (established 16384 bind 16384) [ 0.239529] TCP: reno registered [ 0.239542] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.239568] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.239926] NET: Registered protocol family 1 [ 0.240441] RPC: Registered named UNIX socket transport module. [ 0.240454] RPC: Registered udp transport module. [ 0.240463] RPC: Registered tcp transport module. [ 0.240471] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.240708] Trying to unpack rootfs image as initramfs... [ 0.582081] Freeing initrd memory: 5040K [ 0.582796] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.582949] sunxi_reg_init enter [ 0.584027] audit: initializing netlink socket (disabled) [ 0.584094] type=2000 audit(0.580:1): initialized [ 0.585690] VFS: Disk quotas dquot_6.5.2 [ 0.585887] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.586484] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.586709] misc fatfs initialized [ 0.587025] NFS: Registering the id_resolver key type [ 0.587464] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.587479] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.588336] NTFS driver 2.1.30 [Flags: R/W]. [ 0.588650] fuse init (API version 7.18) [ 0.589065] msgmni has been set to 986 [ 0.590722] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.590744] io scheduler noop registered [ 0.590753] io scheduler deadline registered [ 0.590819] io scheduler cfq registered (default) [ 0.591311] [DISP]disp_module_init [ 0.591648] cmdline,init_disp= [ 0.591682] cmdline,disp= [ 0.592448] [DISP]disp_module_init finish [ 0.592705] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. [ 0.592721] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator. [ 0.592736] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator. [ 0.592750] sw_uart_get_devinfo()1503 - uart3 has no uart_regulator. [ 0.593331] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.593347] sw_uart_pm()890 - uart0 clk is already enable [ 0.593368] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 0.593514] console [ttyS0] enabled [ 0.593860] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 0.594146] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 0.594450] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI [ 0.595000] sunxi_cmatest_init enter [ 0.595050] sunxi_cmatest_init success [ 0.599313] brd: module loaded [ 0.603369] loop: module loaded [ 0.603699] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.603713] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.604369] spi spi0: master is unqueued, this is deprecated [ 0.604878] gmac0 not be used [ 0.604916] gmac0: probe of gmac0 failed with error -22 [ 0.604948] PPP generic driver version 2.4.2 [ 0.605130] PPP BSD Compression module registered [ 0.605140] PPP Deflate Compression module registered [ 0.608257] PPP MPPE Compression module registered [ 0.608278] NET: Registered protocol family 24 [ 0.608380] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.628512] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.628552] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 0.629662] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 0.640054] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 0.640827] hub 1-0:1.0: USB hub found [ 0.640854] hub 1-0:1.0: 1 port detected [ 0.661314] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.661348] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 [ 0.661792] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 [ 0.680044] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 [ 0.680683] hub 2-0:1.0: USB hub found [ 0.680709] hub 2-0:1.0: 1 port detected [ 0.701121] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.701152] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3 [ 0.701600] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000 [ 0.720037] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00 [ 0.720567] hub 3-0:1.0: USB hub found [ 0.720591] hub 3-0:1.0: 1 port detected [ 0.740958] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.740990] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4 [ 0.741383] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000 [ 0.760031] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00 [ 0.760578] hub 4-0:1.0: USB hub found [ 0.760598] hub 4-0:1.0: 1 port detected [ 0.760984] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.781071] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.781101] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5 [ 0.781137] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 [ 0.844578] hub 5-0:1.0: USB hub found [ 0.844601] hub 5-0:1.0: 1 port detected [ 0.864974] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.865004] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6 [ 0.865041] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 [ 0.924604] hub 6-0:1.0: USB hub found [ 0.924626] hub 6-0:1.0: 1 port detected [ 0.945006] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.945036] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7 [ 0.945074] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400 [ 1.004626] hub 7-0:1.0: USB hub found [ 1.004649] hub 7-0:1.0: 1 port detected [ 1.025058] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 1.025090] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8 [ 1.025142] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400 [ 1.084618] hub 8-0:1.0: USB hub found [ 1.084638] hub 8-0:1.0: 1 port detected [ 1.085043] Initializing USB Mass Storage driver... [ 1.085295] usbcore: registered new interface driver usb-storage [ 1.085305] USB Mass Storage support registered. [ 1.085374] usbcore: registered new interface driver ums-alauda [ 1.085428] usbcore: registered new interface driver ums-cypress [ 1.085498] usbcore: registered new interface driver ums-datafab [ 1.085546] usbcore: registered new interface driver ums_eneub6250 [ 1.085593] usbcore: registered new interface driver ums-freecom [ 1.085646] usbcore: registered new interface driver ums-isd200 [ 1.085702] usbcore: registered new interface driver ums-jumpshot [ 1.085752] usbcore: registered new interface driver ums-karma [ 1.085801] usbcore: registered new interface driver ums-onetouch [ 1.085870] usbcore: registered new interface driver ums-realtek [ 1.085929] usbcore: registered new interface driver ums-sddr09 [ 1.085978] usbcore: registered new interface driver ums-sddr55 [ 1.086028] usbcore: registered new interface driver ums-usbat [ 1.086265] uinput result 0 , vmouse_init [ 1.086892] mousedev: PS/2 mouse device common for all mice [ 1.087137] sunxikbd_init failed. [ 1.087975] ls_fetch_sysconfig_para: ls_unused. [ 1.087987] ltr_init: ls_fetch_sysconfig_para err. [ 1.088614] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 [ 1.088674] i2c /dev entries driver [ 1.102754] [ISP] isp platform_id = 5! [ 1.102936] sunxi cedar version 0.1 [ 1.102990] [cedar]: install start!!! [ 1.103253] [cedar]: install end!!! [ 1.103510] twi_start()434 - [i2c0] START can't sendout! [ 1.103777] twi_start()434 - [i2c0] START can't sendout! [ 1.104042] twi_start()434 - [i2c0] START can't sendout! [ 1.104312] twi_start()434 - [i2c0] START can't sendout! [ 1.104577] twi_start()434 - [i2c0] START can't sendout! [ 1.104842] twi_start()434 - [i2c0] START can't sendout! [ 1.105110] twi_start()434 - [i2c0] START can't sendout! [ 1.105375] twi_start()434 - [i2c0] START can't sendout! [ 1.105640] twi_start()434 - [i2c0] START can't sendout! [ 1.105908] twi_start()434 - [i2c0] START can't sendout! [ 1.106173] twi_start()434 - [i2c0] START can't sendout! [ 1.106438] twi_start()434 - [i2c0] START can't sendout! [ 1.106706] twi_start()434 - [i2c0] START can't sendout! [ 1.106971] twi_start()434 - [i2c0] START can't sendout! [ 1.107236] twi_start()434 - [i2c0] START can't sendout! [ 1.107504] twi_start()434 - [i2c0] START can't sendout! [ 1.107769] twi_start()434 - [i2c0] START can't sendout! [ 1.108034] twi_start()434 - [i2c0] START can't sendout! [ 1.108302] twi_start()434 - [i2c0] START can't sendout! [ 1.108567] twi_start()434 - [i2c0] START can't sendout! [ 1.108832] twi_start()434 - [i2c0] START can't sendout! [ 1.109099] twi_start()434 - [i2c0] START can't sendout! [ 1.109365] twi_start()434 - [i2c0] START can't sendout! [ 1.109630] twi_start()434 - [i2c0] START can't sendout! [ 1.109897] twi_start()434 - [i2c0] START can't sendout! [ 1.110069] [VFE_ERR]Error registering v4l2 subdevice No such device! [ 1.110266] twi_start()434 - [i2c0] START can't sendout! [ 1.110532] twi_start()434 - [i2c0] START can't sendout! [ 1.110806] twi_start()434 - [i2c1] START can't sendout! [ 1.111071] twi_start()434 - [i2c1] START can't sendout! [ 1.111336] twi_start()434 - [i2c1] START can't sendout! [ 1.111603] twi_start()434 - [i2c1] START can't sendout! [ 1.111869] twi_start()434 - [i2c1] START can't sendout! [ 1.112134] twi_start()434 - [i2c1] START can't sendout! [ 1.112401] twi_start()434 - [i2c1] START can't sendout! [ 1.112666] twi_start()434 - [i2c1] START can't sendout! [ 1.112931] twi_start()434 - [i2c1] START can't sendout! [ 1.113198] twi_start()434 - [i2c1] START can't sendout! [ 1.113463] twi_start()434 - [i2c1] START can't sendout! [ 1.113728] twi_start()434 - [i2c1] START can't sendout! [ 1.113996] twi_start()434 - [i2c1] START can't sendout! [ 1.114261] twi_start()434 - [i2c1] START can't sendout! [ 1.114526] twi_start()434 - [i2c1] START can't sendout! [ 1.114793] twi_start()434 - [i2c1] START can't sendout! [ 1.115058] twi_start()434 - [i2c1] START can't sendout! [ 1.115323] twi_start()434 - [i2c1] START can't sendout! [ 1.115590] twi_start()434 - [i2c1] START can't sendout! [ 1.115855] twi_start()434 - [i2c1] START can't sendout! [ 1.116120] twi_start()434 - [i2c1] START can't sendout! [ 1.116387] twi_start()434 - [i2c1] START can't sendout! [ 1.116653] twi_start()434 - [i2c1] START can't sendout! [ 1.116918] twi_start()434 - [i2c1] START can't sendout! [ 1.117185] twi_start()434 - [i2c1] START can't sendout! [ 1.117450] twi_start()434 - [i2c1] START can't sendout! [ 1.117715] twi_start()434 - [i2c1] START can't sendout! [ 1.117827] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 [ 1.118011] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf [ 1.118177] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) [ 1.118191] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 [ 1.118203] timeout_to_interv, line 167 [ 1.118211] interv_to_timeout, line 189 [ 1.118221] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec [ 1.118666] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 1.118937] calibrat: max_cpufreq 1200Mhz Type 0! [ 1.118952] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq [ 1.119381] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jul 20 2017 at 11:28:23 [ 1.119420] [mmc]: get mmc0's sdc_power is null! [ 1.119450] [mmc]: get mmc1's sdc_power is null! [ 1.119460] [mmc]: get mmc1's 2xmode ok, val = 1 [ 1.119469] [mmc]: get mmc1's ddrmode ok, val = 1 [ 1.119498] [mmc]: get mmc2's sdc_power is null! [ 1.119507] [mmc]: get mmc2's 2xmode ok, val = 1 [ 1.119517] [mmc]: get mmc2's ddrmode ok, val = 1 [ 1.119530] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2 [ 1.123291] [mmc]: sdc0 power_supply is null [ 1.126877] no red_led, ignore it! [ 1.127142] Registered led device: green_led [ 1.127248] Registered led device: blue_led [ 1.127265] no led_0, ignore it! [ 1.127273] no led_1, ignore it! [ 1.127280] no led_2, ignore it! [ 1.127287] no led_3, ignore it! [ 1.127294] no led_4, ignore it! [ 1.127301] no led_5, ignore it! [ 1.127308] no led_6, ignore it! [ 1.127316] no led_7, ignore it! [ 1.128181] usbcore: registered new interface driver usbhid [ 1.128193] usbhid: USB HID core driver [ 1.129629] script_get_item audio_pa_ctrl not found [ 1.134087] asoc: sndcodec <-> sunxi-codec mapping ok [ 1.135387] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! [ 1.135623] [I2S]snddaudio cannot find any using configuration for controllers, return directly! [ 1.135637] [DAUDIO0] driver not init,just return. [ 1.139573] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok [ 1.141037] oprofile: using arm/armv7-ca7 [ 1.141290] u32 classifier [ 1.141299] Performance counters on [ 1.141307] input device check on [ 1.141315] Actions configured [ 1.141654] TCP: bic registered [ 1.141665] TCP: cubic registered [ 1.141673] TCP: westwood registered [ 1.141681] TCP: highspeed registered [ 1.141689] TCP: hybla registered [ 1.141696] TCP: htcp registered [ 1.141704] TCP: vegas registered [ 1.141712] TCP: veno registered [ 1.141719] TCP: scalable registered [ 1.141727] TCP: lp registered [ 1.141735] TCP: yeah registered [ 1.141743] TCP: illinois registered [ 1.141750] Initializing XFRM netlink socket [ 1.141980] NET: Registered protocol family 10 [ 1.143017] NET: Registered protocol family 17 [ 1.143054] NET: Registered protocol family 15 [ 1.143107] Registering the dns_resolver key type [ 1.143708] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 1.143731] ThumbEE CPU extension supported. [ 1.143758] Registering SWP/SWPB emulation handler [ 1.144392] registered taskstats version 1 [ 1.145459] ths_fetch_sysconfig_para: type err device_used = 1. [ 1.146827] CPU Budget:corekeeper enabled [ 1.147078] CPU Budget:Register notifier [ 1.147092] CPU Budget:register Success [ 1.147106] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 [ 1.150840] [rf_pm]: Did not config module_power0 in sys_config [ 1.150861] [rf_pm]: Did not config module_power1 in sys_config [ 1.150871] [rf_pm]: Did not config module_power2 in sys_config [ 1.150882] [rf_pm]: Did not config module_power3 in sys_config [ 1.150892] [rf_pm]: mod has no chip_en gpio [ 1.150901] [rf_pm]: regulator on. [ 1.150919] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 ! [ 1.237511] mmc0: new high speed SDHC card at address aaaa [ 1.238117] mmcblk0: mmc0:aaaa SS16G 14.8 GiB [ 1.239636] mmcblk0: p1 [ 1.240478] mmcblk mmc0:aaaa: Card claimed for testing. [ 1.240494] mmc0:aaaa: SS16G 14.8 GiB [ 1.242081] [mmc]: sdc2 power_supply is null [ 1.251333] WRN:L148(drivers/usb/sunxi_usb/manager/usb_hcd_servers.c):ERR: unkown usbc_no(5) [ 1.351354] [wifi_pm]: wifi gpio init is OK !! [ 1.351798] [rfkill]: rfkill set power 1 [ 1.364599] mmc2: new high speed DDR MMC card at address 0001 [ 1.365133] mmcblk1: mmc2:0001 8WPD3R 7.28 GiB [ 1.365372] mmcblk1boot0: mmc2:0001 8WPD3R partition 1 4.00 MiB [ 1.365616] mmcblk1boot1: mmc2:0001 8WPD3R partition 2 4.00 MiB [ 1.366984] mmcblk1: p1 p2 [ 1.370196] ALSA device list: [ 1.370208] #0: audiocodec [ 1.370216] #1: sndhdmi [ 1.370414] mmcblk1boot1: unknown partition table [ 1.371271] Freeing init memory: 344K [ 1.372217] mmcblk1boot0: unknown partition table [ 1.372547] mmcblk mmc2:0001: Card claimed for testing. [ 1.372569] mmc2:0001: 8WPD3R 7.28 GiB [ 1.374213] [mmc]: sdc1 power_supply is null [ 1.428027] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.429672] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.431382] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.434324] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.526532] mmc1: new high speed SDIO card at address 0001 [ 1.750232] vmouse_input_dev_open [ 1.830179] vmouse_input_dev_close [ 2.095884] Btrfs loaded [ 2.510249] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 2.996705] systemd[1]: System time before build time, advancing clock. [ 3.460313] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN) [ 3.460692] systemd[1]: Detected architecture arm. [ 3.491017] systemd[1]: Set hostname to <nanopiair>. [ 3.938274] systemd[1]: Created slice User and Session Slice. [ 3.961064] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 3.980509] systemd[1]: Listening on Journal Socket (/dev/log). [ 4.010367] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 4.030453] systemd[1]: Listening on Journal Socket. [ 4.050352] systemd[1]: Listening on fsck to fsckd communication Socket. [ 4.070177] systemd[1]: Reached target Encrypted Volumes. [ 4.090282] systemd[1]: Listening on udev Kernel Socket. [ 4.110404] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 4.130369] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.150568] systemd[1]: Listening on Journal Audit Socket. [ 4.170419] systemd[1]: Started Trigger resolvconf update for networkd DNS. [ 4.190289] systemd[1]: Listening on Syslog Socket. [ 4.210165] systemd[1]: Reached target Remote File Systems (Pre). [ 4.230164] systemd[1]: Reached target Remote File Systems. [ 4.250572] systemd[1]: Created slice System Slice. [ 4.350784] systemd[1]: Starting Load Kernel Modules... [ 4.450553] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 4.470396] systemd[1]: Reached target Slices. [ 4.479696] Registered IR keymap rc-empty [ 4.480328] rc0: sunxi-ir as /devices/virtual/rc/rc0 [ 4.502857] IR RC5(x) protocol handler initialized [ 4.506905] Bluetooth: Core ver 2.16 [ 4.507011] NET: Registered protocol family 31 [ 4.507024] Bluetooth: HCI device and connection manager initialized [ 4.507041] Bluetooth: HCI socket layer initialized [ 4.507054] Bluetooth: L2CAP socket layer initialized [ 4.507082] Bluetooth: SCO socket layer initialized [ 4.512356] Bluetooth: HCI UART driver ver 2.2 [ 4.512375] Bluetooth: HCI H4 protocol initialized [ 4.512384] Bluetooth: HCI BCSP protocol initialized [ 4.512392] Bluetooth: HCILL protocol initialized [ 4.512400] Bluetooth: HCIATH3K protocol initialized [ 4.521423] Bluetooth: RFCOMM TTY layer initialized [ 4.521457] Bluetooth: RFCOMM socket layer initialized [ 4.521467] Bluetooth: RFCOMM ver 1.11 [ 4.526574] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 4.560937] systemd[1]: Starting Restore / save the current clock... [ 4.577186] rc s_cir0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 4.582636] dhd_module_init: in [ 4.582655] ======== bcm_wlan_set_plat_data ======== [ 4.582673] bcm_wlan_get_oob_irq enter. [ 4.582774] gpio [202] map to virq [10] ok [ 4.582782] host_oob_irq: 10 [ 4.582789] host_oob_irq_flags=0x414 [ 4.582797] dhd_wifi_platform_load: Enter [ 4.582838] Power-up adapter 'DHD generic adapter' [ 4.582849] wifi_platform_set_power = 1 [ 4.582857] ======== PULL WL_REG_ON HIGH! ======== [ 4.582867] [wifi_pm]: set wl_reg_on 0 ! [ 4.690479] systemd[1]: Mounting POSIX Message Queue File System... [ 4.782913] [wifi_pm]: set wl_reg_on 1 ! [ 4.890945] systemd[1]: Starting Set console keymap... [ 5.020477] systemd[1]: Mounting Debug File System... [ 5.160861] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 5.290077] wifi_platform_bus_enumerate device present 1 [ 5.290094] ======== Card detection to detect SDIO card! ======== [ 5.290295] dummy_sdmmc: probe of mmc1:0001:1 failed with error -123 [ 5.290335] dummy_sdmmc: probe of mmc1:0001:2 failed with error -123 [ 5.290536] mmc1: card 0001 removed [ 5.290782] [mmc]: sdc1 power_supply is null [ 5.294915] [mmc]: sdc1 power_supply is null [ 5.310527] systemd[1]: Starting Nameserver information manager... [ 5.347264] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 5.348812] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 5.350365] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 5.353129] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 5.442898] mmc1: new high speed SDIO card at address 0001 [ 5.450801] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.459670] bcmsdh_register: register client driver [ 5.459815] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 5.459920] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [ 5.459931] bus num (host idx)=1, slot num (rca)=1 [ 5.459942] found adapter info 'DHD generic adapter' [ 5.460052] sdioh_attach: set sd_f2_blocksize 128 [ 5.460567] F1 signature read @0x18000000=0x1530a9a6 [ 5.463506] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x0 pkg:0x3 [ 5.464556] DHD: dongle ram size is set to 524288(orig 524288) at 0x0 [ 5.464737] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=0 [ 5.464813] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt [ 5.467025] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt [ 5.467831] wl_create_event_handler(): thread:wl_event_handler:c8 started [ 5.467844] tsk Enter, tsk = 0xd51e1430 [ 5.468124] dhd_attach(): thread:dhd_watchdog_thread:c9 started [ 5.468204] dhd_attach(): thread:dhd_dpc:ca started [ 5.468223] dhd_dpc_thread: set dpc_cpucore 0 from config.txt [ 5.468292] dhd_attach(): thread:dhd_rxf:cb started [ 5.468315] dhd_deferred_work_init: work queue initialized [ 5.468750] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt [ 5.468772] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm43438a0.bin [ 5.468787] dhdsdio_download_firmware: set use_rxchain 0 [ 5.468796] dhdsdio_download_firmware: set txglomsize 40 [ 5.468807] sdioh_set_mode: set txglom_mode to multi-desc [ 5.468815] Final fw_path=/lib/firmware/ap6212/fw_bcm43438a0.bin [ 5.468824] Final nv_path=/lib/firmware/ap6212/nvram.txt [ 5.468832] Final conf_path=/lib/firmware/ap6212/config.txt [ 5.470393] systemd[1]: Reached target Paths. [ 5.490703] systemd[1]: Listening on udev Control Socket. [ 5.518735] NVRAM version: AP6212_NVRAM_V1.0_20140603 [ 5.519412] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. [ 5.541081] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 5.573753] systemd[1]: Mounted POSIX Message Queue File System. [ 5.577176] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us) [ 5.577300] bcmsdh_oob_intr_register: Enter [ 5.577309] bcmsdh_oob_intr_register: HW_OOB enabled [ 5.577320] bcmsdh_oob_intr_register OOB irq=10 flags=414 [ 5.577460] bcmsdh_oob_intr_register: disable_irq_wake [ 5.578303] dhd_conf_set_fw_int_cmd: set WLC_SET_BAND 142 0 [ 5.578944] dhd_preinit_ioctls: Set tcpack_sup_mode 0 [ 5.580336] Firmware up: op_mode=0x0001, MAC=94:a1:a2:94:9c:5e [ 5.580350] dhd_conf_set_country: set country CN, revision 0 [ 5.580361] dhd_conf_set_fw_string_struct_cmd: set country [ 5.590380] systemd[1]: Mounted Debug File System. [ 5.644555] Country code: CN (CN/0) [ 5.645252] dhd_conf_set_fw_string_cmd: set roam_off 1 [ 5.659262] Firmware version = wl0: Jun 6 2014 14:50:39 version 7.10.226.49 (r) FWID 01-8962686a [ 5.659280] Driver: 1.201.59.6 (r506368) [ 5.659285] Firmware: wl0: Jun 6 2014 14:50:39 version 7.10.226.49 (r) FWID 01-8962686a [ 5.659302] dhd_txglom_enable: enable 0 [ 5.659312] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0 [ 5.659321] dhd_conf_set_txglom_params: txglom_bucket_size=0 [ 5.659331] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0 [ 5.659342] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0 [ 5.659353] dhd_conf_set_disable_proptx: set disable_proptx 0 [ 5.661771] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64 [ 5.673190] Dongle Host Driver, version 1.201.59.6 (r506368) [ 5.673198] Compiled in drivers/net/wireless/bcmdhd [ 5.674130] Register interface [wlan0] MAC: 94:a1:a2:94:9c:5e [ 5.674240] dhd_module_init: Exit err=0 [ 5.682206] ep_matches, wrn: endpoint already claimed, ep(0xc0a2f1ac, 0xd466ddc0, ep1in-bulk) [ 5.682229] ep_matches, wrn: endpoint already claimed, ep(0xc0a2f1ac, 0xd466ddc0, ep1in-bulk) [ 5.682242] ep_matches, wrn: endpoint already claimed, ep(0xc0a2f1f8, 0xd466ddc0, ep1out-bulk) [ 5.682252] gadget_is_softwinner_otg is not -int [ 5.682260] gadget_is_softwinner_otg is not -int [ 5.682279] g_serial gadget: Gadget Serial v2.4 [ 5.682295] g_serial gadget: g_serial ready [ 5.689672] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 [ 5.760222] systemd[1]: Started Restore / save the current clock. [ 5.920147] systemd[1]: Started Load Kernel Modules. [ 6.090167] systemd[1]: Started Set console keymap. [ 6.230137] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 6.700215] systemd[1]: Started Remount Root and Kernel File Systems. [ 6.920738] systemd[1]: Started Nameserver information manager. [ 7.015234] systemd[1]: Time has been changed [ 7.043839] systemd[1]: Reached target Network (Pre). [ 7.120495] systemd[1]: Activating swap /var/swap... [ 7.226696] Adding 131068k swap on /var/swap. Priority:-1 extents:2 across:139260k SS [ 7.261001] systemd[1]: Starting udev Coldplug all Devices... [ 7.350954] systemd[1]: Starting Load/Save Random Seed... [ 7.500827] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.660441] systemd[1]: Mounting FUSE Control File System... [ 7.790732] systemd[1]: Starting Apply Kernel Variables... [ 7.817888] systemd[1]: Activated swap /var/swap. [ 7.834219] systemd[1]: Mounted FUSE Control File System. [ 8.360285] systemd[1]: Started Load/Save Random Seed. [ 8.480149] systemd[1]: Started Create Static Device Nodes in /dev. [ 8.620144] systemd[1]: Started Apply Kernel Variables. [ 8.760131] systemd[1]: Started udev Coldplug all Devices. [ 8.900888] systemd[1]: Starting udev Kernel Device Manager... [ 8.920282] systemd[1]: Reached target Local File Systems (Pre). [ 9.090470] systemd[1]: Mounting /tmp... [ 9.110437] systemd[1]: Reached target Swap. [ 9.165925] systemd[1]: Started udev Kernel Device Manager. [ 9.194922] systemd[1]: Mounted /tmp. [ 9.214178] systemd[1]: Found device /dev/ttyGS0. [ 9.230657] systemd[1]: Reached target Local File Systems. [ 9.311134] systemd[1]: Starting Armbian enhanced Log2Ram... [ 9.440825] systemd[1]: Starting Raise network interfaces... [ 9.496850] twi_start()434 - [i2c0] START can't sendout! [ 9.497129] twi_start()434 - [i2c0] START can't sendout! [ 9.497395] twi_start()434 - [i2c0] START can't sendout! [ 9.497537] bmp085: probe of 0-0077 failed with error -121 [ 9.497759] twi_start()434 - [i2c0] START can't sendout! [ 9.498030] twi_start()434 - [i2c0] START can't sendout! [ 9.498309] twi_start()434 - [i2c0] START can't sendout! [ 9.498589] twi_start()434 - [i2c0] START can't sendout! [ 9.498858] twi_start()434 - [i2c0] START can't sendout! [ 9.499127] twi_start()434 - [i2c0] START can't sendout! [ 9.591071] systemd[1]: Starting Set console font and keymap... [ 9.623504] vmouse_input_dev_open [ 9.681517] vmouse_input_dev_close [ 9.711136] systemd[1]: Started Entropy daemon using the HAVEGE algorithm. [ 10.025065] systemd[1]: Started Armbian enhanced Log2Ram. [ 10.133428] systemd[1]: Found device /dev/ttyS0. [ 10.360320] systemd[1]: Started Set console font and keymap. [ 10.478733] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 10.500793] systemd[1]: Stopped LSB: Starts LIRC daemon.. [ 10.640887] systemd[1]: Starting LSB: Starts LIRC daemon.... [ 10.720865] systemd[1]: Created slice system-getty.slice. [ 10.740861] systemd[1]: Reached target Sound Card. [ 10.821132] systemd[1]: Starting Journal Service... [ 10.905022] systemd[1]: Started Journal Service. [ 11.173839] [rfkill]: rfkill set power 0 [ 11.514715] systemd-journald[493]: Received request to flush runtime journal from PID 1 [ 16.010578] [rfkill]: rfkill set power 0 [ 16.031254] [rfkill]: rfkill set power 1 [ 16.050690] [rfkill]: rfkill set power 0 [ 17.986559] dhd_open: Enter d51a8000 [ 18.069676] dhd_open: Exit ret=0 [ 20.538215] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 20.538237] Bluetooth: BNEP filters: protocol multicast [ 20.995351] Connectting with 8a:15:04:81:2f:20 channel (1) ssid "Masabi-2.4", len (10) [ 21.004944] wl_iw_event: Link UP with BSSID=8A:15:00:00:2F:20 [ 21.005009] wl_bss_connect_done succeeded with 8a:15:04:81:2f:20 One of the odd things about this logging that I note compared to others is that there is not much comign out of VFE. Have i forgot to include somethign when compiling the kernel? The aim of all of this is to get a build where I can control the focus of the camera. Teh standard build offered my friendlyarm will run the camera, but I can't control the focus with those builds.
Armbian 5.25 on OrangePI PC: The gc2035 video camera doesn't work
dmorse replied to IgZero's question in Orange Pi PC
I added this to the top of my /boot/boot.cmd on that build # DO NOT EDIT THIS FILE gpio set PL10 gpio set PA17 and then make a boot.scr out of it and started up from that. Sill can't see /dev/video0. Still getting this out of dmesg root@orangepizeroplus2:~# dmesg | grep -i gc2035 [ 4.539492] [CSI_ERR][GC2035]sensor_read err at sensor_detect! [ 4.539514] [CSI_ERR][GC2035]chip found is not an target chip. root@orangepizeroplus2:~# -
I don't have a boot.cmd file in /media/boot in that build, only a boot.scr Do you know a way to turn the boot.scr into a boot.cmd for editing and then turn it back? -
I get the same result using the standard ubuntu server build from the orangepi website, but at least with that one I can see /dev/video0. I haven't actually tried to use the device yet, will do that next. root@OrangePI:~# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- root@OrangePI:~# ls /dev/video0 /dev/video0 root@OrangePI:~# -
@Leonardo Lontra I'm not sure how this utility works, but this looks pretty empty to me. root@orangepizeroplus2:~# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- root@orangepizeroplus2:~# -
@Leonardo Lontra Asp previously mentioned, building 5.20 for the pi zero h3 is difficult because that board was not supported back then.
