Hi,
I ran into an issue when configuring ssh. As it seems, ssh listens only to the first interface that is enabled (it seems it is always eth0). Probably, if I set a listen to 192.168.x.x in the config file of the sshd (same as the IP set in the wlan0), and a different network on the ethernet, it would work, but as I won't be using ethernet I would rather disable it completly.
I tried already ifdown, ifconfig down, ifconfig eth0 down && rmmod -f sunxi_gmac, and some others. I even tried removing nmtui just to check if that was causing the problem. all what that step does is removing the bond0 interface (something I would like to do too).
I checked the interface config file and everything seems in order (even tried to comment out everything and also comment out everything and just leaving auto eth0 and the inet dhcp thing - same for wlan0).
But when I reboot, the interface becomes active again.
(sorry if the post is duplicated, but I didn't find anything on the forum)
Is there anything else I can do?
Thanks!
