12 -
BananaPro Wifi unfunctional since apt-get upgrade
HAZArD replied to WolfDonner's topic in Allwinner sunxi
Thanks so much -
it doesn't work :'(
and if I wanted to separate the two things I mean: wlan0=192.168.0.x and eth0=192.168.1.x ?
how you have solved wifi issue? please help me? better if U point me at the right post...
Please I'm exhaust... today is the second day w/o sleeping please tell me step by step how activate the wifi I'm totally out I start writing the image on sd card then update & upgrade and then... I'm stuck here which are the commands to write?... for activate the wifi?
Thank U so much technik007_cz I appreciate your encouragement U know I'm so frustrated... Yes with Armbian_4.5_Bananapi_Ubuntu_trusty_3.4.109_desktop.raw everything works but like I said I would have an headless sys 'cause what I need is just a little nas with some plugins. I'll wait the next release hoping that everything is smooth. In the meantime I try&try&try&try until burning the next sd card
no way armbian is not for me in etc modules I have brcmfmac and bonding wireless setup is ok I can manage it but if I do apt-get install linux-image-banana kernel changes by itself automatically and I lose the connection with the device iwconfig give me this: lo no wireless extensions. eth0 no wireless extensions. bond0 no wireless extensions. tunl0 no wireless extensions. I've already burned a sd card doing always the same thing format&write, format&write, format&write... f&w... etc etc Just for the record I've exactly did what technik007_cz wrote
BEFORE I do apt-get install linux-image-banana root@bananapi:/boot# ls -l total 7396 drwxr-xr-x 2 root root 4096 Oct 11 19:11 bin -rw-r--r-- 1 root root 6944 Oct 11 19:10 boot.bmp -rw-r--r-- 1 root root 1901 Oct 11 19:11 boot.cmd -rw-r--r-- 1 root root 1973 Oct 11 19:11 boot.scr -rw-r--r-- 1 root root 115484 Oct 11 14:12 config-4.2.3-sunxi drwxr-xr-x 2 root root 4096 Oct 11 19:10 dtb lrwxrwxrwx 1 root root 22 Oct 11 19:11 script.bin -> /boot/bin/bananapi.bin -rw-r--r-- 1 root root 1955569 Oct 11 14:12 System.map-4.2.3-sunxi -rwxr-xr-x 1 root root 5468416 Oct 11 14:12 vmlinuz-4.2.3-sunxi lrwxrwxrwx 1 root root 25 Oct 11 19:10 zImage -> /boot/vmlinuz-4.2.3-sunxi AFTER I did apt-get install linux-image-banana root@bananapi:/boot# ls -l total 12904 drwxr-xr-x 2 root root 4096 Oct 11 19:11 bin -rw-r--r-- 1 root root 6944 Oct 11 19:10 boot.bmp -rw-r--r-- 1 root root 1901 Oct 11 19:11 boot.cmd -rw-r--r-- 1 root root 1973 Oct 11 19:11 boot.scr -rw-r--r-- 1 root root 97535 Sep 30 14:21 config-3.4.109-banana drwxr-xr-x 2 root root 4096 Oct 11 19:10 dtb lrwxrwxrwx 1 root root 22 Oct 11 19:11 script.bin -> /boot/bin/bananapi.bin -rw-r--r-- 1 root root 2005221 Sep 30 14:21 System.map-3.4.109-banana -rwxr-xr-x 1 root root 5607544 Sep 30 14:21 vmlinuz-3.4.109-banana -rwxr-xr-x 1 root root 5468416 Oct 11 14:12 vmlinuz-4.2.3-sunxi lrwxrwxrwx 1 root root 28 Jan 20 19:17 zImage -> /boot/vmlinuz-3.4.109-banana I want a headless sys what I can do? someone can help me?
I said "Victory" too quickly I mean: yes the wlan0 and the eth0 work, but the distro change to legacy ubuntu trusty starting from debian wheezy vanilla. If I copy and past the command: apt-get install linux-image-banana then the bananapi stops to workin' no boot, no reachable should I give up?... :'(
YEAAAAAAH it works thank U so much technik007_cz w/o your help I would not have ever made even in terms of explanation (I'm referrin' to Igor) thank U again to U too for your efforts
tonight I'll try this on my device with "Armbian_4.5_Bananapi_Debian_wheezy_4.2.3" Thank U so much for the "step by step" technik007_cz.
Hi to all of U! Igor, I've the same situation! I'm not a linux guru, but this thing drive me crazy, so please consider in the next release the patch for the wifi. We need it! Thank you for your efforts
