sgjava
Everything posted by sgjava
  1. I just installed latest Jammy on XU-4 and it was running fine off SD. Then I did nand-sata-install and you can see below what happened. This used to work fine with older versions. sudo hdparm -Tt /dev/sda /dev/sda: Timing cached reads: 2 MB in 5.54 seconds = 369.48 kB/sec Timing buffered disk reads: 2 MB in 10.33 seconds = 198.19 kB/sec
  2. I was able to get RTL8188FTV $2.00 US USB wifi https://www.ebay.com/itm/123713550193 working with a script I made from a forked project. The power saver has already been disabled in the Makefile. Check out https://github.com/sgjava/rtl8188fu/tree/arm. I've tested this on ARM 32 and ARM 64, but not x86 or x86_64. This is currently a dkms module that requires beta repos to get matching kernel headers.
  3. I figure I'd make this a new post. Thanks to @Markus_ and @Igor for their help. I'm still trying to get wifi module 3 working, but I'm happy to at least have an up to date C1 image. git clone --depth=1 --branch=master https://github.com/armbian/build cd build mkdir -p ./output/debs wget -c -O ./output/debs/linux-u-boot-current-odroidc1_23.02.0-trunk_armhf.deb http://apt.armbian.com/pool/main/l/linux-u-boot-odroidc1-current/linux-u-boot-current-odroidc1_21.02.3_armhf.deb ./compile.sh CLEAN_LEVEL= BOARD=odroidc1 BRANCH=current RELEASE=jammy REPOSITORY_INSTALL= BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no KERNEL_ONLY=no COMPRESS_OUTPUTIMAGE=sha,gpg,img ls ./output/images u-boot has not been able to be built for a while now (last supported image was focal and 5.x kernel). Step 4 copies the last good u-boot to ./output/debs which is created in step 3. Change current in ./output/debs/linux-u-boot-current-odroidc1_23.02.0-trunk_armhf.deb to edge to use edge kernel. Also change build number 23.02.0 to current build number. Step 5 does build without prompting. Change BRANCH=current to BRANCH=edge to build edge branch. If all goes well you should see image with step 6. Issues: reboot not working. Headless, no HDMI. No wifi at this point, just wired. Current branch with 5.x kernel corrupts SD. I found this build totally unusable.
