zet_lab
  1. After the next (last) update, the system does not boot, there is no ssh access, and the monitor does not turn on. I just didn't install updates for three weeks and decided to update yesterday What should I do, re-install the system ? The loader is located on the sd card, and the system is on the hdd, using the 4.4.x kernel
  2. Faced a similar problem, did someone solve it?
  3. I tried the stable Arabian image for rock 64 and found out that full HD video is played with strong brakes, when playing HEVC image is missing How to force video to be reproduced normally, maybe I don't understand something ?
  4. Hello everybody! Just want to apologize for my English, , translate through Google (so for me faster) RockChip allows you to install the image from Linux directly to the emmc, but for this you need to do operations from the computer on which Linux is installed. Here I compiled an archive with the necessary scripts, I've already laid out it on 4pda.ru https://drive.google.com/open?id=0B_N5hzTD0k-XLUJOV3RZU2cyT1k You may need to install any of the packages listed on page 7. (http://opensource.rock-chips.com/images/d/d5/RK3328_Linux-Debian_V1.1_Development_Guide-20170711.pdf) The tv-box should be in the mode of the maskrom. I tried on the original z28 and I ran without a problem the last image from Rosk64 ( )
