The latest version Bookworm cannot start up when use udisk
Perhaps the latest version of the kernel does not support USB drive startup。
The name of image is "Armbian_23.8.0-trunk.71_Aml-s9xx-box_bookworm_edge_6.4.2.img"
The log is as follows:
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
522 bytes read in 28 ms (17.6 KiB/s)
1: Armbian
Retrieving file: /uInitrd
reading /uInitrd
22828930 bytes read in 679 ms (32.1 MiB/s)
Retrieving file: /Image
reading /Image
27617792 bytes read in 802 ms (32.8 MiB/s)
append: root=UUID=deeabe18-1741-4611-8a5a-3581d9f4f77b rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
Retrieving file: /dtb/amlogic/meson-g12a-u200.dtb
reading /dtb/amlogic/meson-g12a-u200.dtb
72501 bytes read in 41 ms (1.7 MiB/s)
[rsvmem] get fdtaddr NULL!
rsvmem - reserve memory
Usage:
rsvmem check - check reserved memory
rsvmem dump - dump reserved memory
rsvmem check failed
## Loading init Ramdisk from Legacy Image at 03080000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 22828866 Bytes = 21.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
active_slot is <NULL>
Unknown command 'store' - try 'help'
No dtbo patitions found
load dtb from 0x1000000 ......
ERROR: Did not find a cmdline Flattened Device Tree
load dtb from 0x0 ......
Could not find a valid device tree
SCRIPT FAILED: continuing...
** Bad device usb 1 **
** Bad device usb 2 **
** Bad device usb 3 **
card out
** Bad device mmc 1 **
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
odroidn2#
