Hi,
I am trying to write my own kernel module/drive for the NanoPi air, running a self-compiled version of armbian 5.83. Actually I only added the PREEMTION option to get real-time behavior when reading/writing from IO pins. I started using the "hello world" template from here. To get the module compiled I had to build the headers for my kernel as well using the option INSTALL_HEADERS in the armbian-build config file. The build debian-package called "linux-headers-next-sunxi_5.83_armhf.deb" was copied and installed on the NanoPi.
OK, so now compiling (on the NanoPi - so no cross-compilation) works like a charm:
> make
make -C /lib/modules/4.19.36-sunxi/build M=/home/gresy/Examples modules
make[1]: Entering directory '/usr/src/linux-headers-4.19.36-sunxi'
CC [M] /home/gresy/Examples/hello.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/gresy/Examples/hello.mod.o
LD [M] /home/gresy/Examples/hello.ko
make[1]: Leaving directory '/usr/src/linux-headers-4.19.36-sunxi'
But when I try to load the hello-world module it's rejected:
> sudo insmod hello.ko
insmod: ERROR: could not insert module hello.ko: Invalid module format
The following message shows up in the kernel buffer, which implies to me the module is not "preemtion compatible" ... if that's possible at all. Or at least the version magic is wrong.
> dmesg
[ 710.970775] hello: version magic '4.19.36-sunxi SMP mod_unload ARMv7 thumb2 p2v8 ' should be '4.19.36-sunxi SMP preempt mod_unload ARMv7 thumb2 p2v8 '
Here some other information which might be useful:
> sudo modinfo hello.ko
filename: /home/gresy/Examples/hello.ko
version: 0.1
description: A simple Hello world LKM!
author: Akshat Sinha
license: GPL
srcversion: B7B3CF8B5A8284B3911C7AF
depends:
vermagic: 4.19.36-sunxi SMP mod_unload ARMv7 thumb2 p2v8
> uname -a
Linux nanopiair 4.19.36-sunxi #5.83 SMP PREEMPT Tue Apr 30 11:04:15 CEST 2019 armv7l GNU/Linux
So, does anyone know why the module will not get loaded?
Thanks for your help,
Markus
