Hello -
First post to this forum - hope it isn't out of line. I have been running Armbian 4.5 on my Lamobo-R1 for a few months. WiFi has been stable, in that connections do not drop, as long as I disable 802.11n.
However, there are two issues that may be related:
1) Throughput is crap - I max out at 8-10 Mbps - which fortunately is sufficient for my needs
2) Huge number of dropped RX packets.
Anything I can do to improve this? I've cut & paste details below.
Regards and thanks,
Ashok
P.S Thomas - if you read this post, perhaps you remember me from more than a decade ago on the netatalk list?
hostapd -v
hostapd v2.5-devel
User space daemon for IEEE 802.11 AP management,
IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator
Copyright © 2002-2015, Jouni Malinen <j@w1.fi> and contributorsl
ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 20:f4:1b:07:81:e2
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:197826 errors:0 dropped:3382973 overruns:0 frame:0
TX packets:207831 errors:0 dropped:104 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:95269704 (90.8 MiB) TX bytes:93574764 (89.2 MiB)
uname -a
Linux bpi-r1 3.4.110-sun7i #10 SMP PREEMPT Mon Dec 28 11:48:43 CET 2015 armv7l GNU/Linux
cat /etc/hostapd/hostapd.conf
# interface
interface=wlan0
bridge=br0
# CTRL-Interface
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
# driver
driver=rtl871xdrv
# SSID
ssid=Ashok's Guest Network
ignore_broadcast_ssid=0
# WLAN
hw_mode=g
ieee80211n=0
channel=1
max_num_sta=8
wmm_enabled=0
wme_enabled=0
# passphrase
wpa_passphrase=######
# WPA2
auth_algs=1
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=CCMP TKIP
rsn_pairwise=CCMP
