joma
joma's Achievements
  1. blacklist dvb_usb_rtl2832u works! Thank you.
  2. Hi, After today upgrade (Kernel / Firmware) my DVB-T pen stop working with dump1090. Error message: /usr/bin/dump1090 --net --gain -10 --modeac --net-bo-port 30005 --net-bi-port 30104 Found 1 device(s): 0: Realtek, RTL2838UHIDIR, SN: 00000001 (currently selected) Kernel driver is active, or device is claimed by second instance of librtlsdr. In the first case, please either detach or blacklist the kernel module (dvb_usb_rtl28xxu), or enable automatic detaching at compile time. usb_claim_interface error -6 Error opening the RTLSDR device: Device or resource busy I tried to follow this tip: http://discussions.flightaware.com/ads-b-flight-tracking-f21/dump1090-not-displaying-data-t19996.htmlwithout results. It's possible to revert the upgrade? Thanks in Advance. Jorge Mota Orange PI PC Jessie 3.4.112-sun8i
  3. Hi, I tried to compile and install this module https://github.com/pvaret/rtl8192cu-fixes but when I run: "sudo dkms install 8192cu/1.10" the result is Building module: cleaning build area..... make KERNELRELEASE=3.4.110-sun8i -C /lib/modules/3.4.110-sun8i/build M=/var/lib/dkms/8192cu/1.10/build......(bad exit status: 2) Error! Bad return status for module build on kernel: 3.4.110-sun8i (armv7l) Consult /var/lib/dkms/8192cu/1.10/build/make.log for more information. make.log content: DKMS make.log for 8192cu-1.10 for kernel 3.4.110-sun8i (armv7l) Sun Feb 28 00:13:37 CET 2016 make: Entering directory '/usr/src/linux-headers-3.4.110-sun8i' LD /var/lib/dkms/8192cu/1.10/build/built-in.o CC [M] /var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o /bin/sh: 1: /usr/src/linux-headers-3.4.110-sun8i/scripts/recordmcount: not found scripts/Makefile.build:307: recipe for target '/var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o' failed make[1]: *** [/var/lib/dkms/8192cu/1.10/build/core/rtw_cmd.o] Error 127 Makefile:1367: recipe for target '_module_/var/lib/dkms/8192cu/1.10/build' failed make: *** [_module_/var/lib/dkms/8192cu/1.10/build] Error 2 make: Leaving directory '/usr/src/linux-headers-3.4.110-sun8i' Note: the package linux-headers-generic is not found also. Any help please? Thanks in Advance.
