Hi KennyM64,
I just had to figure this out for myself on the Hummingboard Edge. The Solidrun article on boot jumpers is a little misleading. Removing the jumpers (at least on an unfused system) boots into USB recovery mode. That's not the same as actually booting from USB. Instead, the board will sit there and wait for SDP (serial download protocol) commands to come in over the USB OTG port.
1. Make a custom cable following instructions here. I used a 1 ohm resistor.
2. Connect the cable to the top USB port next to the ethernet port. (This is the only port with OTG functionality)
3. Follow the instructions here to download and build the imx_usb_loader.
4. Generate SPL and u-boot images or use the attached files. Drop them into the imx_usb_loader folder or adjust the path in the commands below.
4. Run ./imx_usb SPL (if you haven't adjusted your udev rules, you have to use sudo for this and the next command)
5. Once SPL is loaded, run ./imx_usb u-boot.img
You can build Armbian with the CREATE_PATCHES=yes option to adjust U-Boot to include ums support. The changes required are outlined in the link from step 3. Alternately, I've attached my SPL and u-boot.img. My u-boot has ums enabled and activates mmc 1 by default so you shouldn't need a serial cable, although it is nice to see that things are working without the need for a monitor. Once mmc 1 is activated by ums, you should see the board's eMMC flash show up as a USB drive. From here you can flash an image using Etcher, dd, or whatever method you prefer. If the board is actually fused, this may not work. However I saw a Solidrun document somewhere that shows how to hold the eMMC in reset at powerup. In this case, if the board can't boot from eMMC because it's held in reset, that should cause the board to fall back to recovery mode. Either way, once you're in recovery mode, the above steps should work. I hope this helps.
Good luck,
Dale
SPL
u-boot.img
