Hello,
I'm trying an installation of Mastodon instance on tinkerboard running with Armbian OS.
I follow this topic : https://github.com/tootsuite/documentation/blob/master/Running-Mastodon/Production-guide.md
the last command i ran was
bundle install -j$(getconf _NPROCESSORS_ONLN) --deployment --without development test
it returned me :
Fetching: hiredis-0.6.1.gem (100%)
Building native extensions. This could take a while...
ERROR: Error installing hiredis:
ERROR: Failed to build gem native extension.
current directory: /home/mastodon/.rbenv/versions/2.5.0/lib/ruby/gems/2.5.0/gems/hiredis-0.6.1/ext/hiredis_ext
/home/mastodon/.rbenv/versions/2.5.0/bin/ruby -r ./siteconf20180315-22972-ynlyve.rb extconf.rb
checking for sys/socket.h... yes
cc -std=c99 -pedantic -c -O3 -fPIC -Wall -W -Wstrict-prototypes -Wwrite-strings -g -ggdb arm net.c
cc: error: arm: Aucun fichier ou dossier de ce type
Makefile:136 : la recette pour la cible « net.o » a échouée
make: *** [net.o] Erreur 1
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers. Check the mkmf.log file for more details. You may
need configuration options.
Provided configuration options:
--with-opt-dir
--without-opt-dir
--with-opt-include
--without-opt-include=${opt-dir}/include
--with-opt-lib
--without-opt-lib=${opt-dir}/lib
--with-make-prog
--without-make-prog
--srcdir=.
--curdir
--ruby=/home/mastodon/.rbenv/versions/2.5.0/bin/$(RUBY_BASE_NAME)
extconf.rb:33:in `block in <main>': Building hiredis failed (RuntimeError)
from extconf.rb:31:in `chdir'
from extconf.rb:31:in `<main>'
To see why this extension failed to compile, please check the mkmf.log which can be found here:
/home/mastodon/.rbenv/versions/2.5.0/lib/ruby/gems/2.5.0/extensions/armv7l-linux/2.5.0-static/hiredis-0.6.1/mkmf.log
extconf failed, exit code 1
Gem files will remain installed in /home/mastodon/.rbenv/versions/2.5.0/lib/ruby/gems/2.5.0/gems/hiredis-0.6.1 for inspection.
Results logged to /home/mastodon/.rbenv/versions/2.5.0/lib/ruby/gems/2.5.0/extensions/armv7l-linux/2.5.0-static/hiredis-0.6.1/gem_make.out
The problem seems to be that arm files or directory doesn't exist but i didn't find any issues.
Anybody get an idea ?
Thanks a lot and i'm apologize to my English expression.
