andydj
13 -
Switched to nightly and kernel update , now remain hdmiaudio and h264 encoding
Anyone tried hadware encoding whit ffmpeg ?
https://paste.debian.net/1143444 , captured whit tee https://paste.debian.net/1143445/ , log file
For encoding i think i use wrong command ; i use in ffmpeg the option -c:v h264_vaapi and pix-fmt nv12 but i get error This is the output of ffmpeg -ecoders ffmpeg version 3.2.14-1~deb9u1 Copyright (c) 2000-2019 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --prefix=/usr --extra-version='1~deb9u1' --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 34.101 / 55. 34.101 libavcodec 57. 64.101 / 57. 64.101 libavformat 57. 56.101 / 57. 56.101 libavdevice 57. 1.100 / 57. 1.100 libavfilter 6. 65.100 / 6. 65.100 libavresample 3. 1. 0 / 3. 1. 0 libswscale 4. 2.100 / 4. 2.100 libswresample 2. 3.100 / 2. 3.100 libpostproc 54. 1.100 / 54. 1.100 Encoders: V..... = Video A..... = Audio S..... = Subtitle .F.... = Frame-level multithreading ..S... = Slice-level multithreading ...X.. = Codec is experimental ....B. = Supports draw_horiz_band .....D = Supports direct rendering method 1 ------ V..... a64multi Multicolor charset for Commodore 64 (codec a64_multi) V..... a64multi5 Multicolor charset for Commodore 64, extended with 5th color (colram) (codec a64_multi5) V..... alias_pix Alias/Wavefront PIX image V..... amv AMV Video V..... apng APNG (Animated Portable Network Graphics) image V..... asv1 ASUS V1 V..... asv2 ASUS V2 V..... avrp Avid 1:1 10-bit RGB Packer V..X.. avui Avid Meridien Uncompressed V..... ayuv Uncompressed packed MS 4:4:4:4 V..... bmp BMP (Windows and OS/2 bitmap) V..... cinepak Cinepak / CVID V..... cljr Cirrus Logic AccuPak V.S... vc2 SMPTE VC-2 (codec dirac) V.S... dnxhd VC3/DNxHD V..... dpx DPX (Digital Picture Exchange) image VFS... dvvideo DV (Digital Video) V.S... ffv1 FFmpeg video codec #1 VF.... ffvhuff Huffyuv FFmpeg variant V..... flashsv Flash Screen Video V..... flashsv2 Flash Screen Video Version 2 V..... flv FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (codec flv1) V..... gif GIF (Graphics Interchange Format) V..... h261 H.261 V..... h263 H.263 / H.263-1996 V.S... h263p H.263+ / H.263-1998 / H.263 version 2 V..... libx264 libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264) V..... libx264rgb libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 RGB (codec h264) V..... h264_omx OpenMAX IL H.264 video encoder (codec h264) V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hap Vidvox Hap encoder V..... libx265 libx265 H.265 / HEVC (codec hevc) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) VF.... huffyuv Huffyuv / HuffYUV V..... jpeg2000 JPEG 2000 VF.... libopenjpeg OpenJPEG JPEG 2000 (codec jpeg2000) VF.... jpegls JPEG-LS VF.... ljpeg Lossless JPEG VFS... mjpeg MJPEG (Motion JPEG) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) V.S... mpeg1video MPEG-1 video V.S... mpeg2video MPEG-2 video V.S... mpeg4 MPEG-4 part 2 V..... libxvid libxvidcore MPEG-4 part 2 (codec mpeg4) V..... msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2 V..... msmpeg4 MPEG-4 part 2 Microsoft variant version 3 (codec msmpeg4v3) V..... msvideo1 Microsoft Video-1 V..... pam PAM (Portable AnyMap) image V..... pbm PBM (Portable BitMap) image V..... pcx PC Paintbrush PCX image V..... pgm PGM (Portable GrayMap) image V..... pgmyuv PGMYUV (Portable GrayMap YUV) image VF.... png PNG (Portable Network Graphics) image V..... ppm PPM (Portable PixelMap) image VF.... prores Apple ProRes VF.... prores_aw Apple ProRes (codec prores) V.S... prores_ks Apple ProRes (iCodec Pro) (codec prores) V..... qtrle QuickTime Animation (RLE) video V..... r10k AJA Kona 10-bit RGB Codec V..... r210 Uncompressed RGB 10-bit V..... rawvideo raw video V..... roqvideo id RoQ video (codec roq) V..... rv10 RealVideo 1.0 V..... rv20 RealVideo 2.0 V..... sgi SGI image V..... snow Snow V..... sunrast Sun Rasterfile image V..... svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 V..... targa Truevision Targa image V..... libtheora libtheora Theora (codec theora) VF.... tiff TIFF image VF.... utvideo Ut Video V..... v210 Uncompressed 4:2:2 10-bit V..... v308 Uncompressed packed 4:4:4 V..... v408 Uncompressed packed QT 4:4:4:4 V..... v410 Uncompressed 4:4:4 10-bit V..... libvpx libvpx VP8 (codec vp8) V..... libvpx-vp9 libvpx VP9 (codec vp9) V..... libwebp_anim libwebp WebP image (codec webp) V..... libwebp libwebp WebP image (codec webp) V..... wmv1 Windows Media Video 7 V..... wmv2 Windows Media Video 8 V..... wrapped_avframe AVFrame to AVPacket passthrough V..... xbm XBM (X BitMap) image V..... xface X-face image V..... xwd XWD (X Window Dump) image V..... y41p Uncompressed YUV 4:1:1 12-bit V..... yuv4 Uncompressed packed 4:2:0 VF.... zlib LCL (LossLess Codec Library) ZLIB V..... zmbv Zip Motion Blocks Video A..... aac AAC (Advanced Audio Coding) A..... ac3 ATSC A/52A (AC-3) A..... ac3_fixed ATSC A/52A (AC-3) (codec ac3) A..... adpcm_adx SEGA CRI ADX ADPCM A..... g722 G.722 ADPCM (codec adpcm_g722) A..... g726 G.726 ADPCM (codec adpcm_g726) A..... adpcm_ima_qt ADPCM IMA QuickTime A..... adpcm_ima_wav ADPCM IMA WAV A..... adpcm_ms ADPCM Microsoft A..... adpcm_swf ADPCM Shockwave Flash A..... adpcm_yamaha ADPCM Yamaha A..... alac ALAC (Apple Lossless Audio Codec) A..... comfortnoise RFC 3389 comfort noise generator A..X.. dca DCA (DTS Coherent Acoustics) (codec dts) A..... eac3 ATSC A/52 E-AC-3 A..... flac FLAC (Free Lossless Audio Codec) A..... g723_1 G.723.1 A..... libgsm libgsm GSM (codec gsm) A..... libgsm_ms libgsm GSM Microsoft variant (codec gsm_ms) A..X.. mlp MLP (Meridian Lossless Packing) A..... mp2 MP2 (MPEG audio layer 2) A..... mp2fixed MP2 fixed point (MPEG audio layer 2) (codec mp2) A..... libtwolame libtwolame MP2 (MPEG audio layer 2) (codec mp2) A..... libmp3lame libmp3lame MP3 (MPEG audio layer 3) (codec mp3) A..... libshine libshine MP3 (MPEG audio layer 3) (codec mp3) A..... nellymoser Nellymoser Asao A..... libopus libopus Opus (codec opus) A..... pcm_alaw PCM A-law / G.711 A-law A..... pcm_f32be PCM 32-bit floating point big-endian A..... pcm_f32le PCM 32-bit floating point little-endian A..... pcm_f64be PCM 64-bit floating point big-endian A..... pcm_f64le PCM 64-bit floating point little-endian A..... pcm_mulaw PCM mu-law / G.711 mu-law A..... pcm_s16be PCM signed 16-bit big-endian A..... pcm_s16be_planar PCM signed 16-bit big-endian planar A..... pcm_s16le PCM signed 16-bit little-endian A..... pcm_s16le_planar PCM signed 16-bit little-endian planar A..... pcm_s24be PCM signed 24-bit big-endian A..... pcm_s24daud PCM D-Cinema audio signed 24-bit A..... pcm_s24le PCM signed 24-bit little-endian A..... pcm_s24le_planar PCM signed 24-bit little-endian planar A..... pcm_s32be PCM signed 32-bit big-endian A..... pcm_s32le PCM signed 32-bit little-endian A..... pcm_s32le_planar PCM signed 32-bit little-endian planar A..... pcm_s64be PCM signed 64-bit big-endian A..... pcm_s64le PCM signed 64-bit little-endian A..... pcm_s8 PCM signed 8-bit A..... pcm_s8_planar PCM signed 8-bit planar A..... pcm_u16be PCM unsigned 16-bit big-endian A..... pcm_u16le PCM unsigned 16-bit little-endian A..... pcm_u24be PCM unsigned 24-bit big-endian A..... pcm_u24le PCM unsigned 24-bit little-endian A..... pcm_u32be PCM unsigned 32-bit big-endian A..... pcm_u32le PCM unsigned 32-bit little-endian A..... pcm_u8 PCM unsigned 8-bit A..... real_144 RealAudio 1.0 (14.4K) (codec ra_144) A..... roq_dpcm id RoQ DPCM A..X.. s302m SMPTE 302M A..X.. sonic Sonic A..X.. sonicls Sonic lossless A..... libspeex libspeex Speex (codec speex) A..X.. truehd TrueHD A..... tta TTA (True Audio) A..X.. vorbis Vorbis A..... libvorbis libvorbis (codec vorbis) A..... wavpack WavPack A..... libwavpack (codec wavpack) A..... wmav1 Windows Media Audio 1 A..... wmav2 Windows Media Audio 2 S..... ssa ASS (Advanced SubStation Alpha) subtitle (codec ass) S..... ass ASS (Advanced SubStation Alpha) subtitle S..... dvbsub DVB subtitles (codec dvb_subtitle) S..... dvdsub DVD subtitles (codec dvd_subtitle) S..... mov_text 3GPP Timed Text subtitle S..... srt SubRip subtitle (codec subrip) S..... subrip SubRip subtitle S..... text Raw text subtitle S..... webvtt WebVTT subtitle S..... xsub DivX subtitles (XSUB) What can i do to captere the console output ? I'm trying to update kernel from armbian-config from my user with sudo or directly from user root
Many thanks to all 1)Resolution fixed to 1920x1080 , less video artifact but i have no audio and slow on youtube 2) modprobe: FATAL: Module cedrus not found in directory /lib/modules/5.4.28-sunxi64 3) http://ix.io/2jpr
4kp30 video on Orange Pi Lite and mainline hardware acceleration
andydj replied to genesys's topic in Allwinner sunxi
My board Is an Opi One + , i'm offtopic here -
Hi , i have a Orange Pi One plus and i have some problem : 1)video resolution stuck on 1024x768 and less colore bit instead of 1920x1080 in my TV 2)Hardware acceleration in h264 encoding , i don't know how i have to use it 3) when i try ti update kernel i got an error "test install failed"
Modulo cedrus not found in ...../5.4.28-sunxi64 I think i have to move in h6 board forum -
When i try ti update kernel , i got this message Test install failed. Can't change firmware -
Thanks , i try tonight -
What I really have to do ? I'm really noob of this board orange pi one plus -
Hi , hardware encoding is possible on a H6 board whit mainline kernel ? My board is an orange pi one plus
