23 -
Baos's Achievements
Thanks, I was considering that one.
I would like to consolidate some of my devices into a singular device. I am having trouble coming up with a system which could work. currently my cubietruck crashes all the time, so much that it is now on a 2 hour reboot cycle and still manages to crash. I assume it's a power issue with the 3.5 harddrive. Could also be 3Terbyte drive is too much? Also 60mb/s is a bit slow. I have an asus rt-ac87u which does 802.11ac mimo wireless, but I do not like it's operating system. Also the wireless has issues. So, basically looking for something that can support 802.11ac mimo wireless(extra power?) ethernet ports 4-5 sata drive. I have been starting to look at x86 architecture for this(mini-dtx), however I would prefer low noise and low power usage unless it's actually being used.
I have read it again and still do not see your link. mobile version. I posted because of the date on the article of May 11 2016. I wanted to make sure the exploit was not present in what I am using. I had a lot of issues with similar linux exploits in the 90s. For me it is the fear of worms and backdoors.
http://arstechnica.com/security/2016/05/chinese-arm-vendor-left-developer-backdoor-in-kernel-for-android-pi-devices/ Troubling read.
Lost the login motd following apt-get upgrade. Start-Date: 2016-05-08 10:52:11 Commandline: apt-get upgrade Upgrade: linux-image-next-sunxi:armhf (5.04, 5.10), linux-headers-next-sunxi:armhf (5.04, 5.10), linux-trusty-root-next-cubietruck:armhf (5.04, 5.10), linux-dtb-next-sunxi:armhf (5.04, 5.10), linux-firmware-image-next-sunxi:armhf (5.04, 5.10) End-Date: 2016-05-08 10:56:33 I imagine I have to reinstall a pam config file?
For anyone who searches this thread. Here is the most up to date bootable image I could find. uname -a Linux alarm 3.5.7-14-ARCH #1 PREEMPT Mon Jun 30 13:06:45 MDT 2014 armv7l GNU/Linux https://archlinuxarm.org/about/downloads Here is the only ubuntu I could find. I would not recommend as it is no longer supported. https://www.solid-run.com/download/pub/solidrun/cubox/distros/ubuntu/cubox-ubuntu-core-12.10-core-armhf-r1.tar.xz
Discovered it already had a serial device built-in. What a nifty device. elcome to minicom 2.7 OPTIONS: I18n Compiled on Feb 7 2016, 13:37:27. Port /dev/ttyUSB1, 21:04:50 Press CTRL-A Z for help on special keys T T CuBox ** LOADER ** U-Boot 2009.08 (Sep 20 2012 - 02:30:22) Marvell version: 5.4.4 NQ SR1 BootROM: Version on chip: 2.33 Status: OK Retries #: 0 Board: CuBox SoC: 88AP510 (A1) CPU: Marvell Sheeva (Rev 5) CPU @ 800Mhz, L2 @ 400Mhz DDR3 @ 400Mhz, TClock @ 166Mhz PEX 0: interface detected no Link. PEX 1: interface detected no Link. DRAM: 1 GB CS 0: base 0x00000000 size 512 MB CS 1: base 0x20000000 size 512 MB Addresses 60M - 0M are saved for the U-Boot usage. SF: Detected M25P32 with page size 64 kB, total 4 MB Streaming disabled L2 Cache Prefetch disabled L2 Cache ECC disabled Modifying CPU/CORE/DDR power rails to 1.0(-2.5%) / 1.0(-5%) / 1.5(-5%) USB 0: Host Mode USB 1: Host Mode Setting VPU power OFF. Setting GPU power ON. MMC: MV_SDHCI: 0, MV_SDHCI: 1 Net: egiga0 [PRIME] Hit any key to stop autoboot: 0 ===> Executing ext4load usb 0:1 0x02000000 /boot.scr (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 2 USB Device(s) found Waiting for storage device(s) to settle before scanning... scanning bus for storage devices... 0 Storage Device(s) found ** Bad partition 1 ** ===> Executing ext4load usb 1:1 0x02000000 /boot.scr ** Bad partition 1 ** ===> Executing fatload usb 0:1 0x02000000 /boot.scr ** Can't read from device 0 ** ** Unable to use usb 0:1 for fatload ** ===> Executing fatload usb 1:1 0x02000000 /boot.scr ** Can't read from device 1 ** ** Unable to use usb 1:1 for fatload ** ===> Executing ext4load usb 0:1 0x02000000 /boot/boot.scr ** Bad partition 1 ** ===> Executing ext4load usb 1:1 0x02000000 /boot/boot.scr ** Bad partition 1 ** ===> Executing fatload usb 0:1 0x02000000 /boot/boot.scr ** Can't read from device 0 ** ** Unable to use usb 0:1 for fatload ** ===> Executing fatload usb 1:1 0x02000000 /boot/boot.scr ** Can't read from device 1 ** ** Unable to use usb 1:1 for fatload ** ===> Executing ext4load usb 0:2 0x02000000 /boot.scr ** Bad partition 2 ** ===> Executing ext4load usb 1:2 0x02000000 /boot.scr ** Bad partition 2 ** ===> Executing fatload usb 0:2 0x02000000 /boot.scr ** Can't read from device 0 ** ** Unable to use usb 0:2 for fatload ** ===> Executing fatload usb 1:2 0x02000000 /boot.scr ** Can't read from device 1 ** ** Unable to use usb 1:2 for fatload ** ===> Executing ext4load usb 0:2 0x02000000 /boot/boot.scr ** Bad partition 2 ** ===> Executing ext4load usb 1:2 0x02000000 /boot/boot.scr ** Bad partition 2 ** ===> Executing fatload usb 0:2 0x02000000 /boot/boot.scr ** Can't read from device 0 ** ** Unable to use usb 0:2 for fatload ** ===> Executing fatload usb 1:2 0x02000000 /boot/boot.scr ** Can't read from device 1 ** ** Unable to use usb 1:2 for fatload ** ===> Executing ext4load mmc 0:1 0x02000000 /boot.scr Device: MV_SDHCI Manufacturer ID: 3 OEM: 5344 Name: SL32G Tran Speed: 25000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 31914983424 Bus Width: 4-bit Loading file "/boot.scr" from mmc device 0:1 mmcda1 ** File not found /boot.scr ===> Executing fatload mmc 0:1 0x02000000 /boot.scr reading /boot.scr ** Unable to read "/boot.scr" from mmc 0:1 ** ===> Executing ext4load mmc 0:1 0x02000000 /boot/boot.scr Loading file "/boot/boot.scr" from mmc device 0:1 mmcda1 747 bytes read ## Executing script at 02000000 ## Error: "autodetectfdt" not defined ** No boot file defined ** usage: fatload <interface> <dev[:part]> <addr> <filename> [bytes] ** No boot file defined ** Loading file "/boot/zImage" from mmc device 0:1 (mmcda1) ** File not found /boot/zImage reading zImage ** Unable to read "zImage" from mmc 0:1 ** Loading file "zImage" from mmc device 0:1 mmcda1 ** File not found zImage Unknown command 'bootz' - try 'help' ===> Executing fatload mmc 0:1 0x02000000 /boot/boot.scr reading /boot/boot.scr ** Unable to read "/boot/boot.scr" from mmc 0:1 ** ===> Executing ext4load mmc 0:2 0x02000000 /boot.scr ** Bad partition 2 ** ===> Executing fatload mmc 0:2 0x02000000 /boot.scr ** Partition 2 not valid on device 0 ** ** Unable to use mmc 0:2 for fatload ** ===> Executing ext4load mmc 0:2 0x02000000 /boot/boot.scr ** Bad partition 2 ** ===> Executing fatload mmc 0:2 0x02000000 /boot/boot.scr ** Partition 2 not valid on device 0 ** ** Unable to use mmc 0:2 for fatload ** ===> Executing ext4load ide 0:1 0x02000000 /boot.scr Reset IDE: Marvell Serial ATA Adapter Integrated Sata device found ** Bad partition 1 ** ===> Executing fatload ide 0:1 0x02000000 /boot.scr Error No HD connection ** Can't read from device 0 ** ** Unable to use ide 0:1 for fatload ** ===> Executing ext4load ide 0:1 0x02000000 /boot/boot.scr ** Bad partition 1 ** ===> Executing fatload ide 0:1 0x02000000 /boot/boot.scr Error No HD connection ** Can't read from device 0 ** ** Unable to use ide 0:1 for fatload ** ===> Executing ext4load ide 0:2 0x02000000 /boot.scr ** Bad partition 2 ** ===> Executing fatload ide 0:2 0x02000000 /boot.scr Error No HD connection ** Can't read from device 0 ** ** Unable to use ide 0:2 for fatload ** ===> Executing ext4load ide 0:2 0x02000000 /boot/boot.scr ** Bad partition 2 ** ===> Executing fatload ide 0:2 0x02000000 /boot/boot.scr Error No HD connection ** Can't read from device 0 ** ** Unable to use ide 0:2 for fatload ** Using egiga0 device TFTP from server 192.168.15.100; our IP address is 192.168.15.223 Filename 'boot.scr'. Load address: 0x2000000 Loading: T T T T T T T T T T Retry count exceeded; starting again Using egiga0 device TFTP from server 192.168.15.100; our IP address is 192.168.15.223 Filename 'boot.scr'. Load address: 0x2000000 Loading: T T T T T
This is a first gen cubox, half did not have a serial port. I would need a pinout to connect to what might be a serial port. I could not find an archive image from months/years ago to try. And yes, nothing at all, no hdmi signal.
Maybe I missed something, it's been a few weeks since I needed to install an image. cubox with hdmi does not boot. There is no serial port, so I can not even try to figure it out. Also it never requests an ip address from the router. Tried with trusty legacy and vanilla. Used the link specifically labeled cubox-i http://www.armbian.com/cubox-i/
Just threw my asus rt-ac87u in the bin because I got tired of it malfunctioning. I no longer like asus products. So, for the moment I had to turn my cable modem back into a gateway. That said, I found allwinner owns an OUI DC446D and applied it.
My cubietruck mac address which I am assuming is auto generated is invalid. Though one would think it should work, other software on routers will not accept the mac as valid, and thus I can not add configurations to it. We probably need a layer somewhere to create 'valid' mac addresses. 02:C2:07:C0:B7:C7 is the generated mac that my cubietruck is currently using which software claims is invalid.
I will not be running a 15 hour test. And It's now a 3tb drive. I would be willing to do .5 of a tb at most. I don't think one needs to fill the harddrive to run a decent test. Also the only stat I actually care about is how fast I can transfer files off it via an ftp client or any other, smb, nfs, etc.(75mb/s max on armbian, 20-30mb/s using netbsd) Last year I lived out in the country and my max speed most of the time was 0.3kps. I'm in the city now, when I get 10mb/s download it's great.
I tried the test, 7 hours later it was still writing files. I closed the test and turned transmission back on.
Will I loose any data using that?
I wonder if it makes a difference that mine is formated ext4.
