Hello All,
Le Potato aml-s905x-cc 1gb found some useful items for this neat piece of hardware:
ADAFRUIT INDUSTRIES 954 USB-TO-TTL SERIAL CABLE, RASPBERRY PI (1 piece) (excellent cable for console access)
comes with 4 wires (Black - GND, White - TX, Green - RX, Red - Power), using the power adapter, leave the red connector off
Use a terminal program (PuTTY, etc) and set the baud at 115,200, 8 data bits, 1 stop bits, and no parity, no flow control
Need good wireless adapter which works:
MK electronics 150 Mbps USB Wi-Fi Adapter Network Wlan Adapter Stick Windows Mac Linux Desktop PC Notebooks 150 MBit - Ralink 5370 chipset
This works fine when plugged into the USB of the Le Potato, and you can use 'nmtui' to configure the adapter, and make sure that 'automatically connect' and 'enable for all users' are selected. I also turned off IPv6 configuration for 'wlan0'. Also, for the IP addressing, make sure you use the form <IP ADDR/Netmask in CIDR>, i.e. 192.168.1.20/24 (which will set the netmask at 255.255.255.0)
Hope this information helps someone getting their Le Potato up and running...
Anyone else find items which work well with Le Potato, post replies here so that everyone can benefit
