AndiH
4 -
testers wanted Next major upgrade v5.60
AndiH replied to Igor's topic in Advanced users - Development
Hello, I did again some testing with the actual Nightly builds on an Odroid HC1, and detected an issue - the DNS name resolution doesn't work properly. Reason is that the configuration file "/etc/NetworkManager/NetworkManager.conf" now contains a line "dns=None". After just deleting this line from NetworkManager.conf, it works fine - and NetworkManager is updating "/etc/resolv.conf" accordingly. (Note: with "dns=none", the DHCP client ("dhclient" resp. "dhclient-script" would have to take care of the "resolv.conf" update - but that script gets never called, as "dhclient" is started with the -sf option, and will instead invoke the NetworkManage "nm-dhcp-helper" component). I found the issue trying the following images: 5.46.180602_Odroidxu4_Debian_stretch_next_4.9.103 5.46.180602_Odroidxu4_Debian_stretch_dev_4.14.47 5.46.180530_Odroidxu4_Debian_stretch_dev_4.14.44 It was fine (i.e. "NetworkManager.conf" does not contain the "dns=none" line) in: 5.44.180506_Odroidxu4_Debian_stretch_next_4.14.39 5.45_Odroidxu4_Debian_stretch_next_4.9.99 So must happened somewhere in between ... Andi. -
I noticed one little glitch with the Nightly version on an Odroid HC1: (Armbian_5.44.180506_Odroidxu4_Debian_stretch_next_4.14.39 - but the issue is also present in a version from previous days). Seems there is no "/sys/class/net/eth0" device … instead it is named now "enx" + MAC address: root@odroidxu4:~# ls /sys/class/net enx001e0630c906 lo The script /etc/init.d/armhwinfo queries eth0 via ifconfig, and makes some tweaks to the RPS settings of the eth0 device … those commands doesn't work anymore as eth0 is not there (see first and last 2 output rows below): root@odroidxu4:~# /etc/init.d/armhwinfo start eth0: ERROR while getting interface flags: No such device [ ok ] Setting cfg I/O scheduler for sda [ ok ] Setting noop I/O scheduler for mmcblk0 [ ok ] Starting ARM hardware info: Odroid HC1 (5.44.180506) /etc/init.d/armhwinfo: line 137: /sys/class/net/eth0/queues/rx-0/rps_cpus: No such file or directory /etc/init.d/armhwinfo: line 139: /sys/class/net/eth0/queues/rx-0/rps_flow_cnt: No such file or directory -
I tried the solution, and can confirm that it works fine, the boot delay is gone :-) Perfect, and thanks a lot! -
Hello, I did some testing with the Nightly Build Image for the Odroid HC1 / XU4, and made 2 observations: First a nice one: Seems the idle power consumption with the Nightly Build is even lower than with the current Stable Version (measured with an "ELV Energy Master", and very same Hardware for HC1 / SD Card / HDD in standby): 4.0 - 4.1 Watts with 5.43.180423 nightly, Debian stretch, kernel 4.14.35-odroidxu4 4.3 Watts with 5.41 stable, Debian jessie, 4.9.86-odroidxu4 During the boot process however there seems to be some 12 seconds delay on the Odroid HC1, which does not occur on a XU4. Seems the Kernel is running into some timeout? (Perhaps because the HC1 is headless and has no HDMI?) Here the "dmesg" output on the HC1 (with ARMBIAN 5.43.180423 nightly): [ 2.269968] exynos-gsc 13e00000.video-scaler: Linked as a consumer to 13e80000.sysmmu [ 2.270023] iommu: Adding device 13e00000.video-scaler to group 6 [ 2.271205] exynos-gsc 13e10000.video-scaler: Linked as a consumer to 13e90000.sysmmu [ 2.271263] iommu: Adding device 13e10000.video-scaler to group 7 [ 14.599003] device-mapper: uevent: version 1.0.3 [ 14.599314] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com And here the same on the XU4 (used exactly same SD Card): [ 2.265929] exynos-gsc 13e00000.video-scaler: Linked as a consumer to 13e80000.sysmmu [ 2.265984] iommu: Adding device 13e00000.video-scaler to group 6 [ 2.267160] exynos-gsc 13e10000.video-scaler: Linked as a consumer to 13e90000.sysmmu [ 2.267219] iommu: Adding device 13e10000.video-scaler to group 7 [ 2.291153] device-mapper: uevent: version 1.0.3 [ 2.291472] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com Up to this point, the messages in "dmesg" match line-by-line on HC1 and XU4 (of course, the timestamps vary slightly). The Odroid HC1 with the current stable build image (5.41, kernel 4.9.86) doesn't not show such a delay in the boot process. Not a big deal, but I thought to report it here ...
