Carlos_Tico
5 -
How to enable Desktop in Armbian Stretch Image ?
Carlos_Tico replied to Carlos_Tico's topic in Beginners
You mean using this builds in my case: https://dl.armbian.com/orangepiplus2e/nightly/ Thanks -
How to enable desktop in Armbian Stretch mainline kernel 4.14.y IMG ??
Clean Installation of Armbian Stretch mainline kernel 4.14.y to the internal memory of the Orange PI 2018-05-10 09:38:51: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:21: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:22: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:52: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device 2018-05-10 09:39:53: (mod_accesslog.c.180) writing access log entry failed: /var/log/lighttpd/access.log No space left on device pi@orangepiplus2e:~$ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk1: 14.6 GiB, 15634268160 bytes, 30535680 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x6ea0214e Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 8192 30230303 30222112 14.4G 83 Linux Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/sda: 7.6 GiB, 8103395328 bytes, 15826944 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000 Device Boot Start End Sectors Size Id Type /dev/sda1 * 2 15826943 15826942 7.6G 7 HPFS/NTFS/exFAT
Fresh installation of Armbian On OrangePi+ 2e Not Shutting Down
Carlos_Tico replied to Carlos_Tico's question in Orange Pi Plus 2E
Nothing really ? Is this a normal behavior ? -
Carlos_Tico posted a question in Orange Pi Plus 2E
Fresh installation of Armbian On OrangePie+ 2e Not Shutting Down Network lights still on ..... BT still On but not SSH connectivity neither image on monitor any ideas ? Thanks
