I run into the same issue. My system consists out of:
Odroid HC1
SDCard: 32GB Scandisk Ultra
SSD: Samsung EVO 860 250GB
Armbian image: Armbian_5.41_Odroidxu4_Debian_jessie_next_4.9.86
Running a fresh Armbian installation on the sdcard is working flawless. Once I use armbian-conf/system/install (nand-sata-install) to move the system to my SSD my system ends up in a loop during boot. See below how my HC1 boots using UART:
U-Boot 2017.05-armbian (Mar 09 2018 - 06:06:57 +0100) for ODROID-XU4
CPU: Exynos5422 @ 800 MHz
Model: Odroid XU4 based on EXYNOS5422
Board: Odroid XU4 based on EXYNOS5422
Type: xu4
DRAM: 2 GiB
MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 1
MMC Device 0 ( SD ): 29.7 GiB
Card did not respond to voltage select!
mmc_init: -95, time 11
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Press quickly 'Enter' twice to stop autoboot: 0
** Unrecognized filesystem type **
** File not found /boot.ini **
12400 bytes read in 19 ms (636.7 KiB/s)
cfgload addr = 0x50000000, Loading boot.ini from ext4 0:1 /boot/boot.ini
cfgload: applying boot.ini...
cfgload: setenv initrd_high "0xffffffff"
cfgload: setenv fdt_high "0xffffffff"
cfgload: setenv macaddr "00:1e:06:61:7a:55"
cfgload: setenv rootdev UUID=ed131532-0780-430a-8441-53df7188b6c5
cfgload: setenv rootfstype ext4
cfgload: setenv console "both"
cfgload: setenv verbosity "1"
cfgload: if ext4load mmc 0:1 0x44000000 /boot/armbianEnv.txt || fatload mmc 0:1 0x44000000 armbianEnv.txt || ext4load mmc 0:1 0x44000000 armbianEnv.txt; then env import -t 0x44000000 ${filesize}; fi
** File not found /boot/armbianEnv.txt **
** File not found armbianEnv.txt **
cfgload: if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty1"; fi
cfgload: if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "${consoleargs} console=ttySAC2,115200n8"; fi
cfgload: setenv bootrootfs "${consoleargs} consoleblank=0 loglevel=${verbosity} panic=10 root=${rootdev} rootfstype=${rootfstype} rootwait rw"
cfgload: setenv vout "hdmi"
cfgload: setenv cecenable "false" # false or true
cfgload: setenv governor "performance"
cfgload: setenv ddr_freq 825
cfgload: setenv HPD "true"
cfgload: setenv hdmi_tx_amp_lvl "31"
cfgload: setenv hdmi_tx_lvl_ch0 "3"
cfgload: setenv hdmi_tx_lvl_ch1 "3"
cfgload: setenv hdmi_tx_lvl_ch2 "3"
cfgload: setenv hdmi_tx_emp_lvl "6"
cfgload: setenv hdmi_clk_amp_lvl "31"
cfgload: setenv hdmi_tx_res "0"
cfgload: setenv hdmi_phy_control "hdmi_tx_amp_lvl=${hdmi_tx_amp_lvl} hdmi_tx_lvl_ch0=${hdmi_tx_lvl_ch0} hdmi_tx_lvl_ch1=${hdmi_tx_lvl_ch1} hdmi_tx_lvl_ch2=${hdmi_tx_lvl_ch2} hdmi_tx_emp_lvl=${hdmi_tx_emp_lvl} hdmi_clk_amp_lvl=${hdmi_clk_amp_lvl} hdmi_tx_res=${hdmi_tx_res} HPD=${HPD} vout=${vout}"
cfgload: ext4load mmc 0:1 0x40008000 /boot/zImage || fatload mmc 0:1 0x40008000 zImage || ext4load mmc 0:1 0x40008000 zImage
6062464 bytes read in 486 ms (11.9 MiB/s)
cfgload: ext4load mmc 0:1 0x42000000 /boot/uInitrd || fatload mmc 0:1 0x42000000 uInitrd || ext4load mmc 0:1 0x42000000 uInitrd
4091659 bytes read in 338 ms (11.5 MiB/s)
cfgload: if test "${board_name}" = "xu4"; then setenv fdtfile "exynos5422-odroidxu4.dtb"; fi
cfgload: if test "${board_name}" = "xu3"; then setenv fdtfile "exynos5422-odroidxu3.dtb"; fi
cfgload: if test "${board_name}" = "xu3l"; then setenv fdtfile "exynos5422-odroidxu3-lite.dtb"; fi
cfgload: if ext4load mmc 0:1 0x00000000 "/boot/.next" || fatload mmc 0:1 0x00000000 ".next" || ext4load mmc 0:1 0x00000000 ".next"; then echo "Found mainline kernel configuration"; else setenv fdtfile "exynos5422-odroidxu3.dtb"; fi
0 bytes read in 16 ms (0 Bytes/s)
cfgload: ext4load mmc 0:1 0x44000000 /boot/dtb/${fdtfile} || fatload mmc 0:1 0x44000000 dtb/${fdtfile} || ext4load mmc 0:1 0x44000000 dtb/${fdtfile}
61714 bytes read in 64 ms (941.4 KiB/s)
cfgload: fdt addr 0x44000000
cfgload: if test "${cecenable}" = "false"; then fdt rm /cec@101B0000; fi
cfgload: setenv bootargs "${bootrootfs} ${videoconfig} smsc95xx.macaddr=${macaddr} governor=${governor} ${hdmi_phy_control} usb-storage.quirks=${usbstoragequirks} ${extraargs}"
cfgload: dmc ${ddr_freq}
cfgload: bootz 0x40008000 0x42000000 0x44000000
Kernel image @ 0x40008000 [ 0x000000 - 0x5c8180 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4091595 Bytes = 3.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 44000000
Booting using the fdt blob at 0x44000000
Using Device Tree in place at 44000000, end 44012111
Starting kernel ...
Loading, please wait...
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Begin: Will now check root file system ... fsck from util-linux 2.25.2
[/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1
/dev/sda1: clean, 37907/15269888 files, 1235827/61049633 blocks
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
Welcome to Debian GNU/Linux 8 (jessie)!
Expecting device dev-ttySAC2.device...
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Encrypted Volumes.
[ OK ] Reached target Paths.
[ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point.
Expecting device dev-disk-by\x2duuid-0ad83cb2\x2dcc5...ad17c.device...
[ OK ] Created slice Root Slice.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-systemd\x2dfsck.slice.
Starting Increase datagram queue length...
Starting Restore / save the current clock...
Starting Nameserver information manager...
Mounting Debug File System...
Starting udev Coldplug all Devices...
Starting Create list of required static device nodes...rrent kernel...
Mounting POSIX Message Queue File System...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-getty.slice.
Starting Load Kernel Modules...
[ OK ] Reached target Slices.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Started Increase datagram queue length.
[ OK ] Started Restore / save the current clock.
[ OK ] Started Create list of required static device nodes ...current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Nameserver information manager.
[ OK ] Started udev Coldplug all Devices.
Mounting FUSE Control File System...
Starting Apply Kernel Variables...
Mounting Configuration File System...
Starting Create Static Device Nodes in /dev...
[ OK ] Listening on Syslog Socket.
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
Starting Copy rules generated while the root was ro...
Starting LSB: Set preliminary keymap...
Starting LSB: Tune IDE hard disks...
[ OK ] Started Copy rules generated while the root was ro.
[ OK ] Started LSB: Tune IDE hard disks.
[ OK ] Found device /dev/ttySAC2.
[ OK ] Found device /dev/disk/by-uuid/0ad83cb2-cc57-4b0e-bf45-b722be0ad17c.
Starting File System Check on /dev/disk/by-uuid/0ad8...b722be0ad17c...
[ OK ] Reached target Sound Card.
[ OK ] Started LSB: Set preliminary keymap.
Starting Remount Root and Kernel File Systems...
[ OK ] Started Remount Root and Kernel File Systems.
Activating swap /var/swap...
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp...
[ 73.913360] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd: unable to read itable block
[ 73.913398] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #10879130: comm systemd-udevd: reading directory lblock 0
[ 73.913654] EXT4-fs (sda1): Remounting filesystem read-only
[ 73.942151] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd: unable to read itable block
Starting Load/Save Random Seed...
[ 73.984204] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm mount: unable to read itable block
[ 73.996366] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm mount: unable to read itable block
[ OK ] Started File System Check on /dev/disk/by-uuid/0ad83...5-b722be0ad17c.
[FAILED] Failed to activate swap /var/swap.
See 'systemctl status var-swap.swap' for details.
[DEPEND] Dependency failed for Swap.
[FAILED] Failed to mount /tmp.
See 'systemctl status tmp.mount' for details.
[DEPEND] Dependency failed for Local File Systems.
[FAILED] Failed to start Load/Save Random Seed.
See 'systemctl status systemd-random-seed.service' for details.
[ OK ] Stopped Serial Getty on ttySAC2.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped getty on tty2-tty6 if dbus and logind are not available.
[ OK ] Stopped target Graphical Interface.
[ OK ] Stopped Entropy daemon using the HAVEGE algorithm.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped Regular background program processing daemon.
[ OK ] Stopped OpenBSD Secure Shell server.
[ OK ] Stopped Network Manager.
[ OK ] Stopped /etc/rc.local Compatibility.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped Login Service.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Reached target Login Prompts.
[ OK ] Stopped LSB: Start NTP daemon.
[ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Stopped LSB: Start/stop sysstat's sadc.
[ OK ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[ OK ] Stopped LSB: set CPUFreq kernel parameters.
[ OK ] Stopped LSB: disk temperature monitoring daemon.
[ OK ] Stopped LSB: start DirMngr daemon.
[ OK ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Reached target Remote File Systems.
[ OK ] Stopped LSB: Armbian gathering hardware information.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped target Basic System.
[ OK ] Reached target Timers.
[ OK ] Stopped target System Initialization.
Starting Restore Sound Card State...
Starting Create Volatile Files and Directories...
Starting LSB: Prepare console...
Starting LSB: Raise network interfaces....
[ 74.861480] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #14286890: comm kbd: reading directory lblock 0
[ 74.870845] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #14286890: comm kbd: reading directory lblock 0
Starting Armbian enhanced Log2Ram...
[ OK ] Closed Syslog Socket.
[ OK ] Reached target Sockets.
Starting Emergency Shell...
[ OK ] Started Emergency Shell.
[ OK ] Reached target Emergency Mode.
Mounting /media/mmcboot...
[ 75.027218] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #1572865: block 6291488: comm systemd: unable to read itable block
[ 75.038482] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #1572865: block 6291488: comm systemd: unable to read itable block
[ 75.051023] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #1572865: block 6291488: comm systemd: unable to read itable block
[ OK ] Started Restore Sound Card State.
[ OK ] Started LSB: Prepare console.
[ OK ] Started LSB: Raise network interfaces..
[FAILED] Failed to mount /media/mmcboot.
See 'systemctl status media-mmcboot.mount' for details.
[DEPEND] Dependency failed for /boot.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting LSB: Set console font and keymap...
[ OK ] Started LSB: Set console font and keymap.
[ 80.001231] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #10616833: block 42467360: comm (plymouth): unable to read itable block
[ 84.962063] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #4456457: comm systemd-tmpfile: reading directory lblock 0
[ 84.973012] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 90.103613] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #10616833: block 42467360: comm (echo): unable to read itable block
[ 95.197807] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 95.210996] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 105.351764] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #10616833: block 42467360: comm (sh): unable to read itable block
[ 105.437956] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #4456453: comm systemd-tmpfile: reading directory lblock 0
[FAILED] Failed to start Trigger Flushing of Journal to Persistent Storage.
See 'systemctl status systemd-journal-flush.service' for details.
[ OK ] Stopped Trigger Flushing of Journal to Persistent Storage.
Stopping Journal Service...
[ OK ] Stopped Journal Service.
Starting Journal Service...
[ OK ] Started Journal Service.
Starting Trigger Flushing of Journal to Persistent Storage...
[ ***] (1 of 2) A start job is running for Create Volatile ... 8s / no limit)[ 136.157903] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #4456500: comm systemd-tmpfile: reading directory lblock 0
[*** ] (1 of 2) A start job is running for Create Volatile ...19s / no limit)[ 146.397826] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #4456457: comm systemd-tmpfile: reading directory lblock 0
[*** ] A start job is running for Create Volatile Files and...29s / no limit)[ 156.637790] EXT4-fs error (device sda1): ext4_find_entry:1469: inode #4456457: comm systemd-tmpfile: reading directory lblock 0
[** ] (2 of 2) A start job is running for Trigger Flushing...(8s / no limit)[ 187.357839] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 187.370664] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 187.384043] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[*** ] A start job is running for Create Volatile Files and...10s / no limit)[ 197.597842] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 197.610702] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 197.624029] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ **] (1 of 2) A start job is running for Create Volatile ...20s / no limit)[ 207.837784] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 207.850776] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 207.863990] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ *** ] (1 of 2) A start job is running for Create Volatile ...30s / no limit)[ 218.077811] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 218.090819] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 218.104003] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[** ] A start job is running for Create Volatile Files and...41s / no limit)[ 228.317952] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 228.330734] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ 228.344238] EXT4-fs error (device sda1): __ext4_get_inode_loc:4363: inode #12976129: block 51904544: comm systemd-tmpfile: unable to read itable block
[ *** ] (1 of 2) A start job is running for Create Volatile ...50s / no limit)
Next I have re-installed a fresh image on the SDCard again after which I am able to apply some checks on the SSD.
# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1 179:0 0 29.7G 0 disk
└─mmcblk1p1 179:1 0 29.4G 0 part /
sda 8:0 0 232.9G 0 disk
└─sda1 8:1 0 232.9G 0 part
# fdisk /dev/sda
Welcome to fdisk (util-linux 2.25.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 33553920 bytes
Disklabel type: gpt
Disk identifier: 145892EA-EEA0-4E81-B3E6-1EE17BA3C428
Device Start End Sectors Size Type
/dev/sda1 64 488397134 488397071 232.9G Linux filesystem
# fsck -f /dev/sda1
e2fsck 1.42.12 (29-Aug-2014)
/dev/sda1: recovering journal
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda1: 37907/15269888 files (0.1% non-contiguous), 1235827/61049633 blocks
