I want to change kernel config,but not success.
here is my config-default.conf
KERNEL_ONLY="" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt
KERNEL_CONFIGURE="yes" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt
CLEAN_LEVEL="make,debs,oldcache"
DEST_LANG="en_US.UTF-8" # sl_SI.UTF-8, en_US.UTF-8
KERNEL_KEEP_CONFIG="no" # do not overwrite kernel config before compilation
EXTERNAL="yes" # build and install extra applications and drivers
EXTERNAL_NEW="prebuilt" # compile and install or install prebuilt additional packages
CREATE_PATCHES="no" # wait that you make changes to uboot and kernel source and creates patches
BUILD_ALL="no" # cycle through available boards and make images or kernel/u-boot packages.
BSPFREEZE="" # freeze armbian packages (u-boot, kernel, dtb)
INSTALL_HEADERS="" # install kernel headers package
when enter kernel config menu,I save to my.config ,and then I change my.config setting
CONFIG_STRICT_DEVMEM=n
then I load my.config back .
then GUI will ask " Do you wish to save your new configuration ? <ESC><ESC> x to continue"
I chose yes.
then It will create Armbian_5.41_Orangepione_Ubuntu_xenial_default_3.4.113.img,then I clone to sd card.
I boot orange pi one ,then check kernel config setting
cat /proc/config.gz | gunzip > mykernel.conf
always be CONFIG_STRICT_DEVMEM=y
how could I change this kernel config setting??
thanks help~
