dwonga
dwonga's Achievements
  1. Thank for your for suggestion, Igor. I will give it a try. Right now I am using the beta repository but not alternative DEV kernel. I will the information here if I am able to solve this issue. Moreover, thank you for that great job you do here, with armbian. It is trully appreciated. David.
  2. I've managed to use this card but with a TV, using HDMI, instead of this LG monitor. Maybe this problem is related with LG monitor is widescreen and LCD TV is not. Who knows? Anyone has been able to change the resolution to manual, overriding the resolution that HDMI requests? Thank you for any comment. D.
  3. Hi guidol, I have an HDMI Monitor (an LG 25UM58-P), with no adapters. Thanks for any advise you can give.
  4. Hi everyone. I got a Orange Pi Prime (OPi Prime). It works ok with "official" debian and ubuntu images from Xulong (xulong web site). When I try to use Armbian 5.33 stable, I got some text into HDMI screen until the words "loading kernel", then nothing is shown on monitor; but through TTL port I can login as root. That behaviour is repeated wheter using Ubuntu (desktop or server), Debian (desktop or server). With Legacy kernel (3.x) the same card worked in the past, but the image is not available anymore. I'm attaching the output from TTL console: Here is when the HDMI Monitor (an LG 25UM58-P), starts to shown black screens, alternating with "out of range" messages. But in the console, I can see the kernel is loading fine: Your suggestions would be trully aprreciated! David.
