Ram
  1. Hi All I am using Banana Pi Zero. I have installed the Armbian OS in the SD card. Log In working successfully. I want to enable the UART in the Banana Pi Zero with Armbian OS. I want to get the internet connection using GSM module with UART. If you have any appropriate link for this plz message me. Command Output: 1. root@mintboxlite:~# uname -r 3.4.113-sun8i (Kernel Version) --------------------------------------- 2. root@mintboxlite:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=bananapim2zero BOARD_NAME="Banana Pi M2 Zero" BOARDFAMILY=sun8i VERSION=5.41 LINUXFAMILY=sun8i BRANCH=default ARCH=arm IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage -------------------------- 3. root@mintboxlite:~# dmesg | grep tty [ 0.000000] Kernel command line: root=UUID=fa26cc3d-091a-4510-ba3f-f12f36bff240 rootwait rootfstype =ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic= 10 consoleblank=0 loglevel=1 ubootpart=ce9cea4f-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u, 0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable =memory swapaccount=1 [ 0.000000] console [tty1] enabled [ 0.547802] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.547987] console [ttyS0] enabled [ 0.548404] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 0.548697] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 0.548994] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI [ 4.111940] systemd[1]: Expecting device dev-ttyS0.device... [ 5.110580] systemd[1]: Starting system-serial\x2dgetty.slice. [ 5.130252] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 5.130411] systemd[1]: Starting system-getty.slice. [ 5.150169] systemd[1]: Created slice system-getty.slice. [ 7.530201] systemd[1]: Found device /dev/ttyS0. Can anyone help me. I have not found any proper documentation for UART and Sim Module Configuration. Thanks in advance.
