shanevanj
  1. Original boot.cmd: setenv bootargs "console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1" after nand-sata-install - (before reboot) root@bananapim2:/boot# cat boot.cmd setenv bootargs "console=tty1 root=/dev/sda1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1" After reboot red light goes off, display clears, UDB HDD led comes on and then nothing else shows on display.
  2. as a noob - I don't know how to do this since it does not come up after than changes....must I insert SD into another system and where would I find them ?
  3. I have tried to use the nand-sata-install to allow me to boot the roots from an external USB HDD. It goes through the process but after rebooting, the "loading kernel" message appears and then nothing - I have tried this a few times and even used the latest version of the script on GitHub. Any ideas on how to make this work - I have a external USB HDD (500mB).
  4. Hi, another BANANAPI-M2 sucker here.... It is so sad that a H/W manufacturer releases a great piece of hardware and has no ability to provide the software to make it achieve its potential - ARMBIAN is the best distro I have used so far for this type of board, however I will think very long and hard before buying another Bananapi product. Sound is broken, video is broken and probably a few other things I can't find yet due to no proper drivers/support. Any ideas on how to make some of the good stuff work on this board?
