Pbaumann
Content Count
12 -
About Pbaumann
Rank
Member
Armbian 20.05.1 Focal images could be broken
Pbaumann replied to danman's topic in Allwinner H2 & H3
Hi, shame on me! Your'e completly right, this image works with another SDCARD. The broken one was out of the box and looked good, nothing seemed to be wrong. I apologize very much for any inconvenience and would like to thank you for the quick help. Best wishes Paul -
I tried now with Armbian_20.05.4_Cubox-i_focal_current_5.6.18.img.xz also no luck, nothing on screen nothing on serial console... -
Hi, Focal Desktop Image (Armbian_20.05.2_Cubox-i_focal_current_5.6.15_desktop.img.xz) does not start at all on Cubox-i4. Only black screen. How can I provide helpful information? I double checked the image, it seems to be ok. I also checked the filesystem on the SDCARD with fsck it has noerrors. Best wishes Paul -
Cubox can't boot after apt update && apt ugrade
Pbaumann replied to Pbaumann's topic in NXP (Freescale)
Shure. Restoring the last backup to a new sdcard did the job. -
Cubox Path /sys/class/leds/imx6:red:front no longer existing
Well that wired after uninstalling "avahi" the path '/sys/class/leds/imx6:red:front' is back again. I've no clue why. As far as I know avahi is not releted to the missing path. If anyone has an explanation, please post it. Best wishes Paul -
Hi, coming from "ARMBIAN 5.73 stable Ubuntu 18.04.2 LTS 4.19.20-cubox" after performing apt udate apt upgrade my cubox won't boot anymore. I've no idea how to recover from this. The output from boot is in the attached picture. What can I do?
That's strange. On my Cubox the profiles are stored in /etc/NetworkManager/system-connections Best wishes Paul
Hi, I've seen the same behavior on my cubox. You may try this (a really ugly workaround): 1.) create with nmtui a config ( e.g. MyNetCfg) 2.) add this line to your crontab: @reboot /bin/sleep 60 && /usr/bin/nmcli connection up MyNetCfg A litte bit better would be a one-shot service wich starts after network.target. If anyone has a better solution: Please post it! Best wishes Paul Baumann
xrdp doesn't work well on Cubox with Bionic 5.4.4
Hard to say. I'm running only Pihole and a mysql database on my CuBox. Bionic, CuBox, mysql and PiHole are running well. Can't tell if you will have issues running another config. Since some initial issues were carried out Bionic and CuBox works well. -
Thanks for fast response and for clarifying this. For my use case it will be the best to stay with xenial. --- Update After some research I figured out what to do: sudo apt install xrdp sudo apt install xorgxrdp echo "env -u SESSION_MANAGER -u DBUS_SESSION_BUS_ADDRESS xfce4-session"> ~/.xsession After this xrdp runs as expected on bionic. If you're not forced to use xrdp, you might also consider to use x2go. Best wishes Paul -
Hi, I installed xrdp with armbian-config. Now I'm able to login with rdp client, but I'm directed to an empty desktop. No bars/menue or similar, just empty no chance of doing something useful. What's wrong? Best wishes Paul
