Hi,
I have the following bash script in /usr/local/bin/
#!/bin/bash
echo none > /sys/class/leds/green\:ph24\:led1/trigger
#GB: New for 4.2 kernel+
echo none > /sys/class/leds/bananapi\:green\:usr/trigger
That will turn off the green LED.
And then to turn off the blue LED with:
#!/bin/bash
/usr/local/bin/bpi_ledset eth0 b
You need to have bpi_ledset from https://github.com/n1tehawk/bpi_ledset
Then to have these run at boot I've got the following in /etc/rc.local
#!/bin/bash
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
/usr/local/bin/blueoff.sh &
/usr/local/bin/greenoff.sh &
exit 0
