jmaus
  1. Absolute awesome. Thank you @Igor for the fast response. Now all the kernel and kernel headers are there and I can compile additional kernel modules. Highly appreciated!
  2. Yes, indeed. I just checked that myself as well. Newer experimental Armbian (v24, edge, current) contains the corresponding header and image deb files for the RaspberryPi5. However, not the latest stable version. Furthermore, the stable version for the RaspberryPi4 seems to be affected as well. Also there I can't install the corresponding linux-headers package patching the currently running kernel version. See: # apt install linux-headers-$(uname -r) Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.1.68-current-bcm2711 E: Couldn't find any package by glob 'linux-headers-6.1.68-current-bcm2711' And the same applies for the linux-image package: # apt reinstall linux-image-current-bcm2711 Reading package lists... Done Building dependency tree... Done Reading state information... Done Reinstallation of linux-image-current-bcm2711 is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Hopefully some Armbian dev can fix that ASAP so that the corresponding linux-headers and linux-image packages for the RaspberryPi5 and RaspberryPi4 are available in the apt repositories.
  3. I was about to ask/write the same here. I am also in need of the corresponding kernel headers for the 6.1.68.current-bcm2712 kernel distributed with Armbian for RaspberryPi5. In addition, I just recognized that kernel reinstallation also does not work because the kernel image package also seems to be missing in the apt repositories as it seems. See here: # apt reinstall linux-image-current-bcm2712 Reading package lists... Done Building dependency tree... Done Reading state information... Done Reinstallation of linux-image-current-bcm2712 is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Thus, would be great if some armbian dev (perhaps the maintainer – @viraniac – of the RaspberryPi5 port, see https://www.armbian.com/rpi5b/) can have a look and provide the necessary packages...
