vanjo9800
  1. Hello, I have an Orange Pi PC with Armbian. I like the distribution very much, but I face a strange problem. After around 5 minutes of use I cannot longer open applications. When I switch to tty I see the following error: end_request: I/O error, dev mmcblk0, sector 3477952 mmcblk0: timed out sending r/w cmd command , card status 0xe00 mmcblk0: not retrying timeout At first I thought the problem was in the SD card, I scanned it - no bad sectors. Then I tried with the card from my Raspberry Pi which works perfectly with it. I copied the image with DD and I had the same error again. What could the problem be? A software one, or something in the power supply, because I see no other obvious reason?
