RBM Posted April 13, 2016 Posted April 13, 2016 Hi there, Just loaded Armbian Vanilla Jessie (5.00, 4.4.1 kernel) on one of my Cuboxes. There's no sound from SPDIF, even though it's seen: root@cubox-i:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: SPDIF [integrated SPDIF], device 0: S/PDIF PCM snd-soc-dummy-dai-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 Speaker-test shows no errors: root@cubox-i:~# speaker-test -r 44100 -F S16_LE -c 2 -D hw:0,0 speaker-test 1.0.28 Playback device is hw:0,0 Stream parameters are 44100Hz, S16_LE, 2 channels Using 16 octaves of pink noise Rate set to 44100Hz (requested 44100Hz) Buffer size range from 64 to 16384 Period size range from 32 to 8192 Using max buffer size 16384 Periods = 4 was set period_size = 4096 was set buffer_size = 16384 0 - Front Left 1 - Front Right Time per period = 5.607037 0 - Front Left 1 - Front Right It all appears to work – except for the actual sound coming out. Tried with 2 different Cuboxes. Armbian Legacy (3.14.60) outputs sound OK. Any ideas?
