Settled here on using the AmiLogic S912 for my KODI boxes replacing the current Aopen Digital Engines.
Purchased another AmiLogic S912 here to be utilized as a headless automation server running:
1 - Mono
2 - Homeseer 3
3 - Home Assistant - docker
4 - Node Red
5 - MQTT (and be a Mosquitto Server).
Note mini automation server started with an RPi (years ago), MiniCube (dual AMD) then a Pine64 (currently running with Armbian).  Moving this one to the Leviton Media panel.
Looking to modify hardware a bit adding a RTC with battery.  I have modded a few non RTC tabletop tablets and OpenWRT routers with RTC and used a bit of bit banging and these are working fine today.
Has anyone modded a TV box yet with an RTC?
  • Werner locked this topic
