Hi all.
I've made a new video about x11vnc. With this you can control your Linux desktop from any other PC/SBC.
It even works for videos and games. Only there's no sound.
I use lightdm as display manager. If you use another display manager, change the line "After=lightdm.service" with your display manager.
Here's my video,
To Install
sudo apt install x11vnc
To create a password file
x11vnc -storepasswd
The service script : /lib/systemd/system/x11vnc.service
[Unit]
Description="x11vnc"
Requires=display-manager.service
[Service]
ExecStart=/usr/bin/x11vnc -auth guess -loop -forever -safer -shared -ultrafilexfer -bg -o /var/log/x11vnc.log
ExecStop=/usr/bin/killall x11vnc
[Install]
WantedBy=multi-user.target
Enable the service script
sudo systemctl daemon-reload
sudo systemctl enable x11vnc
sudo systemctl start x11vnc
greetings. NicoD
On 5/8/2019 at 9:38 PM, NicoD said:
Hi all.
Here's my video,
To Install
x11vnc -storepasswd
[Unit]
[Service]
[Install]
greetings. NicoD
If you want to use password the correct line should be "-rfbauth /home/USERNAME/.vnc/passwd"
ExecStart=/usr/bin/x11vnc -auth guess -loop -forever -safer -rfbauth /home/USERNAME/.vnc/passwd -shared -ultrafilexfer -bg -o /var/log/x11vnc.log
USERNAME = is your own username. not "rahul"..
