Hello
I have a problem with the configuration of the PMU and the temperature . All information that I have found so far for the kernel 3.4 . However, I use 4.4.3 . I am using SSH Login me in the Cubietruck then be at the beginning all temperatures displayed correctly .where I find this script ?
thanks for your help
What you're witnessing is well-known, support for the PMU (axp209) disappeared from 4.x kernel, then it probably re-appeared or something
Take a look here though, looks like a member managed to get it working with armbianmonitor.
