vingaard Posted May 21, 2019 Posted May 21, 2019 (edited) Hello, I just ran a apt-update Sunday on a project and afterwards the XU only have Black screen with blinking _ in the corner, not connecting to LAN, no ssh, etc; red led is on, blue led blinking, no new logs in /var/log. Google' the issue, and several posts points to the /boot dir - however comparing with a know good SD card, I can't see much difference in this directory - other forum post points that a /dev mount point should be changed (but not to what) I can mount the broken SD card and have the following info; /etc/armbian.txt Title: Armbian 5.73 Odroidxu4 Ubuntu bionic next Kernel: Linux 4.14.94 Build date: 28.01.2019 /etc/armbian-release VERSION=5.73 I does seems to be very like below mention issue - however no applicable fix was provided - any assistance in how to unbrick the XU would be most appreciated (beside the obvious start over ) Edited May 22, 2019 by lanefu Moved to other supported section
