When I build for Olimex-A10 with the sunxi I2S drivers enabled, build fails. Without this driver, its building/ working fine without issues. I am compiling with 3.4.x and with Jessie. I tried compiling it even as a module but with same result.
the lines just before the failure are pasted below:
 In file included from drivers/staging/wlan-ng/prism2usb.c:5:0:        x
   x drivers/staging/wlan-ng/prism2fw.c: In function âwriteimage.constprop.37â:        x
   x drivers/staging/wlan-ng/prism2fw.c:1115:1: warning: the frame size of 4240 bytes is larger than 2048 bytes [-Wframe-larger-than=]                                                     x
   x  }        x
   x  ^        x
   x   LD [M]  drivers/staging/usbip/usbip-core.o        x
   x   LD [M]  drivers/staging/usbip/vhci-hcd.o        x
   x   LD [M]  drivers/staging/usbip/usbip-host.o        x
   x In file included from drivers/staging/wlan-ng/p80211netdev.c:91:0:        x
   x drivers/staging/wlan-ng/cfg80211.c: In function âprism2_scanâ:        x
   x drivers/staging/wlan-ng/cfg80211.c:404:22: warning: ignoring return value of âcfg80211_inform_bssâ, declared with attribute warn_unused_result [-Wunused-result]                      x
   x    cfg80211_inform_bss(wiphy,        x
   x                       ^        x
   x   LD [M]  drivers/staging/wlan-ng/prism2_usb.o        x
   x   LD      drivers/staging/built-in.o        x
   x   LD      drivers/built-in.o        x
   mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
[ error ] ERROR in function compile_kernel [ common.sh:236 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
Any pointers on what can be the reason here ?
Thanks,
