Armbianmonitor:
the new version of Armbian (5.83) Does not boot from sd card I tried to install 5.69 it's work normally.
I tried to all the sd card formatter rufus and wın32 disk imager and different sd cards but no way new version does not work anyway. when i burn to 5.69 it boot normally. I guess you have to control the package whıch you upladed for opi pc+
thanks
it does
  ___                               ____  _   ____   ____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |  _ \ / ___|    _
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |_) | |      _| |_
| |_| | | | (_| | | | | (_| |  __/ |  __/| | |  __/| |___  |_   _|
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|    \____|   |_|
                       |___/
Welcome to ARMBIAN 5.83 stable Debian GNU/Linux 9 (stretch) 4.19.38-sunxi
System load:   1.31 0.44 0.16   Up time:       1 min
Memory usage:  7 % of 999MB     IP:            192.168.0.6
CPU temp:      33°C
Usage of /:    3% of 29G
[ General system configuration (beta): armbian-config ]
New to Armbian? Check the documentation first: https://docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
Creating a new user account. Press <Ctrl-C> to abort
http://ix.io/1MHz
https://docs.armbian.com/User-Guide_Getting-Started/
