5.1.0-1111-ayufan tag.
Kernel crash when PCIE card is installed (thus pcie host root complex initialize).
Will try previous tags soon, BTW, if anyone successfully run the "mainline" kernel with PCIE cards?
[  161.895780] io scheduler mq-deadline registered
[  161.897340] io scheduler kyber registered
[  161.911264] io scheduler bfq registered
[  162.136905] vcc5v0_host: supplied by vcc5v0_usb
[  162.740884] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[  162.746764] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[  162.750391] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[  163.280713] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[  163.284059] rockchip-pcie f8000000.pcie:   MEM 0xfa000000..0xfbdfffff -> 0xf0
[  163.286820] rockchip-pcie f8000000.pcie:    IO 0xfbe00000..0xfbefffff -> 0xf0
[  163.302884] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[  163.305119] pci_bus 0000:00: root bus resource [bus 00-1f]
[  163.306968] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[  163.310027] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus add)
[  163.542130] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reg
[  163.560746] SError Interrupt on CPU5, code 0xbf000002 -- SError
[  163.560932] CPU: 5 PID: 1 Comm: swapper/0 Tainted: G             L    5.1.0-3
[  163.561051] Hardware name: Pine64 RockPro64 (DT)
[  163.561157] pstate: 60000085 (nZCv daIf -PAN -UAO)
[  163.561258] pc : rockchip_pcie_rd_conf+0x1e8/0x280
[  163.561356] lr : rockchip_pcie_rd_conf+0x214/0x280
[  163.561440] sp : ffff00001004b7f0
[  163.561527] x29: ffff00001004b7f0 x28: 0000000000000000
[  163.561800] x27: 0000000000000000 x26: 0000000000000000
[  163.562047] x25: 0000000000000004 x24: ffff800004de13c0
[  163.562275] x23: 0000000000000000 x22: ffff8000f61d6800
[  163.562499] x21: ffff00001004b894 x20: 0000000000100000
[  163.562718] x19: 0000000000000000 x18: 0000000000000000
[  163.562936] x17: 00000000250ca3fe x16: 000000009ae7c865
[  163.563154] x15: ffffffffffffffff x14: ffff00001153d6c8
[  163.563374] x13: ffff8000ec3df91c x12: ffff8000ec3df190
[  163.563592] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[  163.563811] x9 : ff72646268756463 x8 : 00000000000003bd
[  163.564030] x7 : 0000000000000000 x6 : 0000000000000001
[  163.564248] x5 : ffff00001060f630 x4 : 0000000000000000
[  163.564466] x3 : 0000000000000000 x2 : 0000000000c00008
[  163.564686] x1 : ffff000017c00008 x0 : 0000000000000000
[  163.564961] Kernel panic - not syncing: Asynchronous SError Interrupt
[  163.565098] CPU: 5 PID: 1 Comm: swapper/0 Tainted: G             L    5.1.0-3
[  163.565196] Hardware name: Pine64 RockPro64 (DT)
[  163.565276] Call trace:
[  163.565367]  dump_backtrace+0x0/0x168
[  163.565452]  show_stack+0x24/0x30
[  163.565535]  dump_stack+0xac/0xd4
[  163.565617]  panic+0x150/0x2e8
[  163.565705]  __stack_chk_fail+0x0/0x28
[  163.565798]  arm64_serror_panic+0x80/0x8c
[  163.565884]  do_serror+0x11c/0x120
[  163.565968]  el1_error+0x84/0xf8
[  163.566064]  rockchip_pcie_rd_conf+0x1e8/0x280
[  163.566164]  pci_bus_read_config_dword+0xb8/0x108
[  163.566271]  pci_bus_generic_read_dev_vendor_id+0x40/0x1b8
[  163.566368]  pci_bus_read_dev_vendor_id+0x58/0x88
[  163.566464]  pci_scan_single_device+0x84/0xf8
[  163.566556]  pci_scan_slot+0x44/0x108
[  163.566653]  pci_scan_child_bus_extend+0x5c/0x350
[  163.566749]  pci_scan_bridge_extend+0x37c/0x518
[  163.566849]  pci_scan_child_bus_extend+0x204/0x350
[  163.566945]  pci_scan_root_bus_bridge+0x60/0xd0
[  163.567042]  rockchip_pcie_probe+0x5ec/0x718
[  163.567135]  platform_drv_probe+0x58/0xa8
[  163.567223]  really_probe+0x1f0/0x3d8
