OpenMediaVault on EspressoBin via Softy - Installation gives errors
Hi there,
I just tried to use armbian-config's softy to install OpenMediaVault on my rather new EspressoBin (v5), but it ended up with a bunch of errors (this is from the terminal at second try of installation - didn't record the errors at first try):
--2019-06-30 22:12:53--  https://packages.openmediavault.org/public/archive.key
Resolving packages.openmediavault.org (packages.openmediavault.org)... 178.254.11.33
Connecting to packages.openmediavault.org (packages.openmediavault.org)|178.254.11.33|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3134 (3.1K) [application/pgp-keys]
Saving to: '/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc'
/etc/apt/trusted.gpg.d/openmediava 100%[================================================================>]   3.06K  --.-KB/s    in 0s
2019-06-30 22:12:53 (19.4 MB/s) - '/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc' saved [3134/3134]
OK
Executing: /tmp/apt-key-gpghome.aOQVltMEVs/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 7AA630A1EDEE7D73
gpg: key 7AA630A1EDEE7D73: "OpenMediaVault Plugin Developers <plugins@omv-extras.org>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
/usr/sbin/softy: line 611: [: 36576: unary operator expected
Now installing OMV packages. Be patient please
(Reading database ... 33546 files and directories currently installed.)
Preparing to unpack .../tmp.9lMoxmevYT/omv_extras.deb ...
Unpacking openmediavault-omvextrasorg (4.1.15) over (4.1.15) ...
/var/lib/dpkg/info/openmediavault-omvextrasorg.postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions
dpkg: warning: subprocess old post-removal script returned error exit status 2
dpkg: trying script from the new package instead ...
/var/lib/dpkg/tmp.ci/postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions
dpkg: error processing archive /tmp/tmp.9lMoxmevYT/omv_extras.deb (--install):
 subprocess new post-removal script returned error exit status 2
dpkg: error while cleaning up:
Errors were encountered while processing:
/usr/sbin/softy: line 636: /usr/share/openmediavault/scripts/helper-functions: No such file or directory
/usr/sbin/softy: line 640: xmlstarlet: command not found
/usr/sbin/softy: line 641: xmlstarlet: command not found
/usr/sbin/softy: line 642: xmlstarlet: command not found
/usr/sbin/softy: line 643: xmlstarlet: command not found
/usr/sbin/softy: line 644: xmlstarlet: command not found
/usr/sbin/softy: line 645: xmlstarlet: command not found
/usr/sbin/softy: line 646: xmlstarlet: command not found
/usr/sbin/softy: line 647: xmlstarlet: command not found
/usr/sbin/softy: line 648: /usr/sbin/omv-rpc: No such file or directory
/usr/sbin/softy: line 649: /usr/sbin/omv-rpc: No such file or directory
sed: can't read /etc/init.d/rrdcached: No such file or directory
--2019-06-30 22:13:57--  https://raw.githubusercontent.com/python/cpython/9cd7e17640a49635d1c1f8c2989578a8fc2c1de6/Lib/weakref.py
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.12.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.12.133|:443... connected.
Length: 20466 (20K) [text/plain]
Saving to: '/usr/lib/python3.5/weakref.py'
/usr/lib/python3.5/weakref.py      100%[================================================================>]  19.99K  --.-KB/s    in 0.02s
2019-06-30 22:13:57 (1.03 MB/s) - '/usr/lib/python3.5/weakref.py' saved [20466/20466]
/usr/sbin/softy: line 732: /usr/sbin/omv-initsystem: No such file or directory
Any suggestions are welcome, thanks in advance.
