Jozko578 Posted July 10, 2019 Posted July 10, 2019 (edited) Hey I've managed to boot armbian on my box with S905X using meson-gxl-s905x-p212.dtb. The thing is that the screen resolution isn't properly setup. For some reason it detects Composite-1 when there's none and HDMI default is 1024x768. This isn't that big of an issue as I was able to use xrandr to fix it for my monitor. However when plugged to something bigger like TV the screen is very weird. Colors start to change color and screen has some weird artifacts. You can watch it here https://streamable.com/2615s A friend of mine has another box and it works perfectly out of the box. The TV is not the issue but rather the dtb. the meson-gxm-khadas-vim2.dtb also works but wifi stops working but the screen resolution has still the same issue. Edited July 10, 2019 by Jozko578 solved blackscreen
