hi all .
i run odoroid-c2
foremaly i runed nginx with auth basic by next nginx.conf successfully in orange pi PC .
nginx.conf is
events {
    worker_connections  800;
http {
    include       mime.types;
    default_type  application/octet-stream;
    index         index.html index.htm;
    keepalive_timeout  65;
    server_tokens off;
server {
        listen       80;
        server_name  localhost;    #<-for test
        #root         /var/www/d1;
        root         /var/www/d2;
server {
        listen       80;
        server_name  n------------n.dip.jp;
        root         /var/www/d2;
    auth_basic           "closed site";
    auth_basic_user_file /var/www/2/.htpasswd;
server {
        listen       80;
        server_name  s----------------s.mydns.jp;
        root         /var/www/d1;
    auth_basic_user_file /var/www/1/.htpasswd;
but [ /etc/init.d/nginx restart ]  fails  in odoroid-c2 .
i love nginx but fail .
so i am forced to run apache2 .
head apache2.conf
NameVirtualHost *:80
<VirtualHost *:80>
ServerName s-----------------s.mydns.jp
DocumentRoot /var/www/d1
</VirtualHost>
<VirtualHost *:80>
ServerName n---------------n.dip.jp
DocumentRoot /var/www/d2
</VirtualHost>
<Directory "/var/www/d1">
    AuthType Basic
    AuthName "D1"
    AuthUserFile /var/www/1/.htpasswd
    Require user emi
</Directory>
<Directory "/var/www/d2">
    AuthType Basic
    AuthName "D2"
    AuthUserFile /var/www/2/.htpasswd
    Require user fuji
</Directory>
what is wrong with nginx.conf ?
regards
thanks for reply .
[....] Restarting nginx (via systemctl): nginx.serviceJob for nginx.service failed. See 'systemctl status nginx.service' and 'journalctl -xn' for details.
 failed!
â— nginx.service - A high performance web server and a reverse proxy server
   Loaded: loaded (/lib/systemd/system/nginx.service; enabled)
   Active: failed (Result: exit-code) since æ°´ 2016-05-04 07:30:04 JST; 45s ago
  Process: 2331 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=1/FAILURE)
  Process: 2389 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
 5月 04 07:30:04 odroidc2 nginx[2389]: nginx: [emerg] could not build the server_...32
 5月 04 07:30:04 odroidc2 nginx[2389]: nginx: configuration file /etc/nginx/nginx...ed
 5月 04 07:30:04 odroidc2 systemd[1]: nginx.service: control process exited, code...=1
 5月 04 07:30:04 odroidc2 systemd[1]: Failed to start A high performance web serv...r.
 5月 04 07:30:04 odroidc2 systemd[1]: Unit nginx.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
journalctl -xn
-- Logs begin at æ°´ 2016-05-04 07:08:39 JST, end at æ°´ 2016-05-04 07:31:08 JST. --
 5月 04 07:30:58 odroidc2 nodm[2417]: pam_systemd(nodm:session): Failed to release sess
 5月 04 07:30:58 odroidc2 nodm[2417]: pam_close_session: Cannot make/remove an entry fo
 5月 04 07:30:58 odroidc2 nodm[580]: X session 2417 quit with status 0
 5月 04 07:30:58 odroidc2 nodm[580]: sending X server 2412 the TERM signal
 5月 04 07:30:58 odroidc2 kernel: fb: osd[0] canvas.idx =0x40
 5月 04 07:30:58 odroidc2 kernel: fb: osd[0] canvas.addr=0x78000000
 5月 04 07:30:58 odroidc2 kernel: fb: osd[0] canvas.width=5760
 5月 04 07:30:58 odroidc2 kernel: fb: osd[0] canvas.height=2160
 5月 04 07:30:58 odroidc2 nodm[580]: session lasted less than 60 seconds: sleeping 60 s
 5月 04 07:31:08 odroidc2 systemd-logind[519]: Removed session c22.
-- Subject: A session c22 has been terminated
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Documentation: http://www.freedesktop.org/wiki/Software/systemd/multiseat
-- A session with the ID c22 has been terminated.
cat /var/log/nginx/error.log
2016/05/02 23:23:45 [emerg] 12720#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/02 23:23:56 [emerg] 12753#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/02 23:26:32 [emerg] 12816#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/02 23:31:02 [emerg] 12960#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/02 23:37:29 [emerg] 13084#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/02 23:40:07 [emerg] 13158#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/03 00:03:03 [emerg] 13518#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
2016/05/04 07:28:53 [emerg] 2248#0: bind() to 0.0.0.0:80 failed (98: Address already in use)
2016/05/04 07:28:53 [emerg] 2248#0: bind() to [::]:80 failed (98: Address already in use)
2016/05/04 07:28:53 [emerg] 2248#0: still could not bind()
2016/05/04 07:28:58 [emerg] 2331#0: bind() to 0.0.0.0:80 failed (98: Address already in use)
2016/05/04 07:28:58 [emerg] 2331#0: bind() to [::]:80 failed (98: Address already in use)
2016/05/04 07:28:58 [emerg] 2331#0: still could not bind()
2016/05/04 07:30:04 [emerg] 2389#0: could not build the server_names_hash, you should increase server_names_hash_bucket_size: 32
SOrry for late reply , but I'm a little confused because in previous message we were talking about another kind of mistake .. about Basic Auth ?
first for Auth
I think your code must be in "location { ..... }" section , not just in  "server { ..... }
this is the way in my configs .... and so is written here http://nginx.org/en/docs/http/ngx_http_auth_basic_module.html
so it will be
server {
        listen       80;
        root         /var/www/d2;
        location / {
as for "you should increase server_names_hash_bucket_size: 32"
check here http://nginx.org/en/docs/http/server_names.html
you have very long site names and .... you should have
http {
    server_names_hash_bucket_size  64;
hope it helps
