Armbianmonitor:
Since debian buster switched to nftables as default, when i want to use the ufw-firewall, the following happens:
root@homecloud:~# ufw enable
Command may disrupt existing ssh connections. Proceed with operation (y|n)? y
ERROR: problem running ufw-init
ip6tables-restore v1.8.3 (nf_tables): unknown option "--icmpv6-type"
Error occurred at line: 36
Try `ip6tables-restore -h' or 'ip6tables-restore --help' for more information.
Problem running '/etc/ufw/before6.rules'
root@homecloud:~#
I installed both iptables and nftables, and also tried the buster-backports versions of both programs, same issue.
When i run the ufw-check-requirements script, i get this:
root@homecloud:~# /usr/share/ufw/check-requirements
Has python: pass (binary: python2.7, version: 2.7.16, py2)
Has iptables: pass
Has ip6tables: pass
Has /proc/net/dev: pass
Has /proc/net/if_inet6: pass
This script will now attempt to create various rules using the iptables
and ip6tables commands. This may result in module autoloading (eg, for
IPv6).
Proceed with checks (Y/n)? y
== IPv4 ==
Creating 'ufw-check-requirements'... done
Inserting RETURN at top of 'ufw-check-requirements'... done
TCP: pass
UDP: pass
destination port: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: pass
LOG: pass
hashlimit: pass
limit: pass
ctstate (NEW): pass
ctstate (RELATED): pass
ctstate (ESTABLISHED): pass
ctstate (INVALID): pass
ctstate (new, recent set): pass
ctstate (new, recent update): pass
ctstate (new, limit): pass
interface (input): pass
interface (output): pass
multiport: pass
comment: pass
addrtype (LOCAL): pass
addrtype (MULTICAST): pass
addrtype (BROADCAST): pass
icmp (destination-unreachable): pass
icmp (source-quench): pass
icmp (time-exceeded): pass
icmp (parameter-problem): pass
icmp (echo-request): pass
== IPv6 ==
Creating 'ufw-check-requirements6'... done
Inserting RETURN at top of 'ufw-check-requirements6'... done
TCP: pass
UDP: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: pass
LOG: pass
hashlimit: pass
limit: pass
ctstate (NEW): pass
multiport: pass
comment: pass
icmpv6 (destination-unreachable): FAIL
error was: ip6tables v1.8.3 (nf_tables): unknown option "--icmpv6-type"
Try `ip6tables -h' or 'ip6tables --help' for more information.
icmpv6 (packet-too-big): FAIL
icmpv6 (time-exceeded): FAIL
icmpv6 (parameter-problem): FAIL
icmpv6 (echo-request): FAIL
icmpv6 with hl (neighbor-solicitation): FAIL
icmpv6 with hl (neighbor-advertisement): FAIL
icmpv6 with hl (router-solicitation): FAIL
icmpv6 with hl (router-advertisement): FAIL
ipv6 rt: pass
FAIL: check your kernel and that you have iptables >= 1.4.0
root@homecloud:~#
Could this be a kernel issue with the standard 4.14 kernel? because i have no issues with the 5.1 dev kernel:
Has iptables: pass
Has ip6tables: pass
IPv6).
== IPv4 ==
TCP: pass
UDP: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: pass
LOG: pass
hashlimit: pass
limit: pass
ctstate (NEW): pass
multiport: pass
comment: pass
== IPv6 ==
TCP: pass
UDP: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: pass
LOG: pass
hashlimit: pass
limit: pass
ctstate (NEW): pass
multiport: pass
comment: pass
icmpv6 (destination-unreachable): pass
icmpv6 (packet-too-big): pass
icmpv6 (time-exceeded): pass
icmpv6 (parameter-problem): pass
icmpv6 (echo-request): pass
icmpv6 with hl (neighbor-solicitation): pass
icmpv6 with hl (neighbor-advertisement): pass
icmpv6 with hl (router-solicitation): pass
icmpv6 with hl (router-advertisement): pass
ipv6 rt: pass
All tests passed
root@homecloud:~#
And the ufw-firewall can be enabled without issue.
Currently, the solution for the odroidxu4 with the standard 4.14 kernel is to switch from iptables-nft (nftables as backend) to iptables-legacy as described here: https://wiki.debian.org/nftables
update-alternatives --set iptables /usr/sbin/iptables-legacy
update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
Is there a way to fix it so nftables can be used with the standard 4.14 kernel?
Sincerely,
cyagon
