ext4 USB mount issues
ReefBum
Received new odroid HC1 today and having issues mounting a seagate 2tb hdd.
armbian odroidxu4/Debian_buster_next
Seagate HDD 2TB
sudo fdisk /dev/sda
created new primary partition
sudo mkfs.ext4 /dev/sda1
mounted  drive ( this works and the drive is mounted )
sudo mount /dev/sda1 /mnt/hdd
but if i try to mount as user it fails
pi@HC1:~$ sudo mount -t uid=pi,gid=pi /dev/sda1 /mnt/hdd
mount: /mnt/hdd: unknown filesystem type.
sudo mount -o uid=pi,gid=pi /dev/sda1 /mnt/hdd
mount: /mnt/hdd: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error.
sudo mount -t ext4 -o gid=pi,uid=pi /dev/sda1 /mnt/hdd
output from fdisk -l
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: 001-1RG174
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xeea250e5
Device     Boot Start        End    Sectors  Size Id Type
/dev/sda1        2048 3907029167 3907027120  1.8T 83 Linux
If I put the drive on usb/adapter with win7 laptop and format partition with ntfs all works perfectly
Why all the issues when formated ext4 and is there a way to solve?
Link to comment
Share on other sites
You are confusing mount options. gid & uid are only for network or local file systems that dont support unix like permissions. They allow you to overlay a fake permissions base over the top of a filesystem that doesnt have the attributes to support unix like permissions
You shouldnt be using uig or gid to mount an ext4 filesystem, by design it will not work. Mount it without any -o gid or uid options and once mounted then you can use chown or chmod to set the native permissions that you want
Link to comment
