Hi there,
want to stick to the 4.4 kernel an tried to compile kernel 4.4.9 via:
apt-get -y install git
git clone https://github.com/igorpecovnik/lib--depth 1
cp lib/compile.sh .
chmod +x compile.sh
./compile.sh
after that, i built the following directory and file:
mkdir userpatches
vi userpatches/lib.config
and added:
KERNELBRANCH=â€v4.4.9â€
as described here:
http://forum.armbian.com/index.php/topic/1008-how-to-compile-latest-kernel-447/
Whenn running ./compile, i get the following messages:
[ o.k. ] Using user configuration override [ userpatches/lib.config ]
[ o.k. ] Starting Armbian build script [ @host ]
[ o.k. ] Compiling kernel [ cubietruck ]
[ o.k. ] Syncing clock [ host ]
[ o.k. ] source downloading [ @host ]
[ o.k. ] ... updating [ u-boot ]
[ o.k. ] ... creating a shallow clone [ linux-vanilla â€v4.4.9†]
Cloning into '/root/sources/linux-vanilla/â€v4.4.9â€'...
warning: Could not find remote branch â€v4.4.9†to clone.
fatal: Remote branch â€v4.4.9†not found in upstream origin
/root/lib/general.sh: line 124: cd: /root/sources/linux-vanilla/â€v4.4.9â€: No such file or directory
fatal: Not a git repository (or any of the parent directories): .git
Any hints?
Thx, Andreas
Please check quotation marks around version - if they were normal, they wouldn't display at all.
This is your double quote symbol: â€
This is normal double quote symbol: "
