NOGARUKA Posted May 10, 2016 Posted May 10, 2016 How to turn off leds on cubietruck? I use Legacy Trusty server
lampra Posted May 10, 2016 Posted May 10, 2016 Try this, it should work with the legacy kernel (not sure though): see available leds $ ls /sys/class/leds/ see available options for eg blue led $ cat /sys/class/leds/blue\:ph21\:led1/trigger Then turn off eg blue led: # echo none > /sys/class/leds/blue\:ph21\:led1/trigger If you need to turn leds off after reboot, put it in an executable script and run the script @reboot in root crontab There are also other options if you do not want the leds to turn on at boot.
NOGARUKA Posted May 12, 2016 Author Posted May 12, 2016 Try thisi cant edit any /sys fileswrite error
