ChrisArena52 Posted May 12, 2016 Posted May 12, 2016 In the "next" Vanilla version of Armbian for CB1: cubie@cubieboard:~/Apps/test-gdb$ uname -a Linux cubieboard 4.5.4-sunxi #1 SMP Wed May 11 16:51:05 EDT 2016 armv7l GNU/Linux cubie@cubieboard:~/Apps/test-gdb$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 8.4 (jessie) Release: 8.4 Codename: jessie The following option is not set in the kernel configuration: CONFIG_OABI_COMPAT=y When this is commented out, debugging fails with an illegal instruction if you do anything other than run, just about. Possibly a coincidence is that "less /proc/config.gz" stops working when that option is set --- dunno. Don't have time to elaborate the options right now. See https://github.com/raspberrypi/linux/issues/766for a discussion. Unless other things break with that option, I prefer being able to debug than to have the convenience of just typing "less /proc/config.gz". Chris
zador.blood.stained Posted May 12, 2016 Posted May 12, 2016 Possibly a coincidence is that "less /proc/config.gz" stops working when that option is set --- dunno. Don't have time to elaborate the options right now. See https://github.com/raspberrypi/linux/issues/766for a discussion. Unless other things break with that option, I prefer being able to debug than to have the convenience of just typing "less /proc/config.gz". config OABI_COMPAT bool "Allow old ABI binaries to run with this kernel (EXPERIMENTAL)" depends on AEABI && !THUMB2_KERNEL help This option preserves the old syscall interface along with the new (ARM EABI) one. It also provides a compatibility layer to intercept syscalls that have structure arguments which layout in memory differs between the legacy ABI and the new ARM EABI (only for non "thumb" binaries). This option adds a tiny overhead to all syscalls and produces a slightly larger kernel. The seccomp filter system will not be available when this is selected, since there is no way yet to sensibly distinguish between calling conventions during filtering. If you know you'll be using only pure EABI user space then you can say N here. If this option is not selected and you attempt to execute a legacy ABI binary then the result will be UNPREDICTABLE (in fact it can be predicted that it won't work at all). If in doubt say N. What GDB package are you using? dpkg -S $(which gdb) There are 2 possibilities - gdb and gdb-arm-none-eabi. This output is from Debian testing: âžœ ~ % apt-cache show gdb gdb-arm-none-eabi Package: gdb Source: gdb (7.10-1) Version: 7.10-1+b1 Installed-Size: 5010 Maintainer: Héctor Orón MartÃnez <zumbi@debian.org> Architecture: armhf Replaces: gdb Depends: libbabeltrace-ctf1 (>= 1.2.1), libbabeltrace1 (>= 1.2.1), libc6 (>= 2.15), libexpat1 (>= 2.0.1), liblzma5 (>= 5.1.1alpha+20110809), libncurses5 (>= 6), libpython3.5 (>= 3.5.0~b1), libreadline6 (>= 6.0), libtinfo5 (>= 6), zlib1g (>= 1:1.2.0) Recommends: libc-dbg, gdbserver Suggests: gdb-doc Conflicts: gdb Description-en: GNU Debugger GDB is a source-level debugger, capable of breaking programs at any specific line, displaying variable values, and determining where errors occurred. Currently, gdb supports C, C++, D, Objective-C, Fortran, Java, OpenCL C, Pascal, assembly, Modula-2, Go, and Ada. A must-have for any serious programmer. Description-md5: 4f2b8eb95df2ba7a5b11e0301c48b8e4 Homepage: http://www.gnu.org/s/gdb/ Tag: devel::debugger, devel::lang:c, devel::lang:c++, devel::lang:fortran, devel::lang:java, implemented-in::c, interface::text-mode, role::program, scope::utility, suite::gnu, uitoolkit::ncurses, works-with::software:running Section: devel Priority: optional Filename: pool/main/g/gdb/gdb_7.10-1+b1_armhf.deb Size: 2268812 MD5sum: 6abf17d834dbd1ef3ef14d4507e35acd SHA1: 914fb61acc8dc3a2f5d7a2b83b9f74156934ca8d SHA256: ba508018ef304d8f1714d04c23a96a2d260bf5a3e913d108e06278b9c3f9671d Package: gdb-arm-none-eabi Source: gdb-arm-none-eabi (9) Version: 7.10-1+9 Installed-Size: 4592 Maintainer: Agustin Henze <tin@debian.org> Architecture: armhf Depends: libc6 (>= 2.11), libexpat1 (>= 2.0.1), libncurses5 (>= 6), libpython2.7 (>= 2.7), libreadline6 (>= 6.0), libtinfo5 (>= 6), zlib1g (>= 1:1.2.0) Recommends: gcc-arm-none-eabi Description-en: GNU debugger for ARM Cortex-A/R/M processors Bare metal GNU debugger for embedded ARM chips using Cortex-M0/M0+/M3/M4, Cortex-R4/R5/R7 and Cortex-A* processors. GDB is a source-level debugger, capable of breaking programs at any specific line, displaying variable values, and determining where errors occurred. Description-md5: c034a489da482847d1aaa1c6157f9f71 Homepage: http://www.gnu.org/s/gdb/ Built-Using: gdb (= 7.10-1) Tag: uitoolkit::ncurses Section: devel Priority: extra Filename: pool/main/g/gdb-arm-none-eabi/gdb-arm-none-eabi_7.10-1+9_armhf.deb Size: 1784102 MD5sum: 1eccfacfc0f1e20479cc5311dd32f4ba SHA1: ef55f18fbbc416f5de515bfb9300931b0af3aec9 SHA256: 1c1bb17c820a2f4ac234f8d263df5d065f369516fd525cfb525d11f361ec0a24
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 OK, this is really killing me now. My gdb is new enough: cubie@cubieboard:~/$ apt-cache show gdb gdb-arm-none-eabi Package: gdb Priority: optional Section: devel Installed-Size: 5051 Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com> Original-Maintainer: Héctor Orón MartÃnez <zumbi@debian.org> Architecture: armhf Version: 7.11-0ubuntu1 Replaces: gdb, gdb-doc (<< 7.8-1~) Depends: libbabeltrace-ctf1 (>= 1.2.1), libbabeltrace1 (>= 1.2.1), libc6 (>= 2.15), libexpat1 (>= 2.0.1), liblzma5 (>= 5.1.1alpha+20110809), libncurses5 (>= 6), libpython3.5 (>= 3.5.0~b1), libreadline6 (>= 6.0), libtinfo5 (>= 6), zlib1g (>= 1:1.2.0) Recommends: libc-dbg, libcc1-0, gdbserver Suggests: gdb-doc Conflicts: gdb Filename: pool/main/g/gdb/gdb_7.11-0ubuntu1_armhf.deb Size: 2229164 MD5sum: a9d02baef1a64fc61b1689a9fed59b0f SHA1: a8581e2ed7ebba9f17eec24cee180d6017d54365 SHA256: c3dc84d8115d41b742189d95aff8168e3cacaa25ee877846990fd16cfaafd947 Description-en: GNU Debugger GDB is a source-level debugger, capable of breaking programs at any specific line, displaying variable values, and determining where errors occurred. Currently, gdb supports C, C++, D, Objective-C, Fortran, Java, OpenCL C, Pascal, assembly, Modula-2, Go, and Ada. A must-have for any serious programmer. Description-md5: 4f2b8eb95df2ba7a5b11e0301c48b8e4 Multi-Arch: allowed Homepage: http://www.gnu.org/s/gdb/ Bugs: https://bugs.launchpad.net/ubuntu/+filebug Origin: Ubuntu Supported: 9m Task: ubuntu-desktop, ubuntu-usb, kubuntu-desktop, kubuntu-full, edubuntu-desktop, edubuntu-usb, xubuntu-desktop, mythbuntu-frontend, mythbuntu-desktop, mythbuntu-backend-slave, mythbuntu-backend-master, mythbuntu-backend-master, ubuntustudio-desktop, ubuntu-gnome-desktop, ubuntu-touch-core, ubuntu-touch, ubuntu-sdk, ubuntukylin-desktop, ubuntu-mate-desktop Package: gdb-arm-none-eabi Priority: extra Section: universe/devel Installed-Size: 5326 Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com> Original-Maintainer: Agustin Henze <tin@debian.org> Architecture: armhf Source: gdb-arm-none-eabi (9) Version: 7.10-1ubuntu3+9 Depends: libc6 (>= 2.15), libexpat1 (>= 2.0.1), libncurses5 (>= 6), libpython2.7 (>= 2.7), libreadline6 (>= 6.0), libtinfo5 (>= 6), zlib1g (>= 1:1.2.0) Recommends: gcc-arm-none-eabi Filename: pool/universe/g/gdb-arm-none-eabi/gdb-arm-none-eabi_7.10-1ubuntu3+9_armhf.deb Size: 2406174 MD5sum: 4b3656ea81660478e0ed5f27fda67f86 SHA1: 738f1f4016c03108fd74d68f1ce4bd398f17c526 SHA256: 07442d48b1c27953087d8639b90316c2fc8c1044fbee8fe5ded4be09557775f4 Description-en: GNU debugger for ARM Cortex-A/R/M processors Bare metal GNU debugger for embedded ARM chips using Cortex-M0/M0+/M3/M4, Cortex-R4/R5/R7 and Cortex-A* processors. GDB is a source-level debugger, capable of breaking programs at any specific line, displaying variable values, and determining where errors occurred. Description-md5: c034a489da482847d1aaa1c6157f9f71 Built-Using: gdb (= 7.10-1ubuntu3) Homepage: http://www.gnu.org/s/gdb/ Bugs: https://bugs.launchpad.net/ubuntu/+filebug Origin: Ubuntu So what's doing this? I'll rebuild with the OABI_COMPAT set in this new image. What's the long term solution that's not deprecated? Thanks, Chris
zador.blood.stained Posted June 23, 2016 Posted June 23, 2016 What gdb do you have installed? It's either one or another, and I guess gdb-arm-none-eabi is the right one.
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 I have: cubie@cubieboard:/sys/class/gpio/gpio139$ gdb --version GNU gdb (Ubuntu 7.11-0ubuntu1) 7.11 Copyright (C) 2016 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "arm-linux-gnueabihf". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word". This gdb crashes with: Program received signal SIGSEGV, Segmentation fault. 0xb6fd9822 in ?? () from /lib/ld-linux-armhf.so.3 A "hello world" program crashes exactly the same way -- AFAICS. Doing "apt-get install gdb-arm-none-eabi" does not install a binary executable by that name on my CB1. Thanks Chris
zador.blood.stained Posted June 23, 2016 Posted June 23, 2016 Doing "apt-get install gdb-arm-none-eabi" does not install a binary executable on my CB1. Are you sure? ➜ ~ % apt-file show gdb-arm-none-eabi | grep '/bin/' gdb-arm-none-eabi: /usr/bin/arm-none-eabi-gdb gdb-arm-none-eabi: /usr/bin/arm-none-eabi-run
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 OK, that file is there. But it is behaving as though the target should be a remote ... "run" gives me a "Don't know how to run. Try help target". But it's not SIGSEGV-ing at least. This is weird ... why does THIS gdb behave differently from any other native gdb? I can't get it the program to start. Is this a proxy program or something? I'm not connected via a serial line. I'm trying to run a native program on the CB1 under the debugger. Thanks Chris
zador.blood.stained Posted June 23, 2016 Posted June 23, 2016 Hm. I just installed "normal" gdb on cubietruck (Debian stretch, kernel 4.6.2) and it doesn't crash for me at least in simple scenarios ➜ ~ % gdb axp20x-calibrate-battery GNU gdb (Debian 7.10-1.1) 7.10 Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "arm-linux-gnueabihf". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from axp20x-calibrate-battery...(no debugging symbols found)...done. (gdb) run Starting program: /home/zador/axp20x-calibrate-battery axp20x battery calibration tool v1.1 Usage: axp20x-calibrate-battery [-h | -p | -e | -l <file> | -s <file>] Arguments: -h: Show this help message and exit -p: Print configuration -e: Edit configuration -s <file>: Save OCV table to <file> -l <file>: Load and apply OCV table from <file> [Inferior 1 (process 28435) exited normally] (gdb) quit ➜ ~ % gdb free GNU gdb (Debian 7.10-1.1) 7.10 Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "arm-linux-gnueabihf". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from free...(no debugging symbols found)...done. (gdb) run Starting program: /usr/bin/free [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1". total used free shared buff/cache available Mem: 2061280 181728 146868 2196 1732684 1815424 Swap: 0 0 0 [Inferior 1 (process 28473) exited normally] (gdb) quit ➜ ~ % Program received signal SIGSEGV, Segmentation fault. 0xb6fd9822 in ?? () from /lib/ld-linux-armhf.so.3 Since it crashes in the loader, can you check your system for corrupted packages? sudo apt-get install debsums sudo debsums -cs
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 Do you have CONFIG_OABI_COMPAT set in that kernel?
zador.blood.stained Posted June 23, 2016 Posted June 23, 2016 Do you have CONFIG_OABI_COMPAT set in that kernel? ➜ ~ % zgrep OABI_COMPAT /proc/config.gz # CONFIG_OABI_COMPAT is not set
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 The only thing that debsums -cs complained about was the sun4i-a10-cubieboard.dtb I modified to enable SPI. I'm surprised that the check covered that file. Is there a link option that makes the image "modern" so that the deprecated OABI_COMPAT isn't needed? I'm compiling like: g++ main.cpp -g -o main It's more elaborate with multiple .o files when I link, but essentially like that.
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 An actual compile line is: g++ -c -std=c++11 -fno-rtti -D__packed="__attribute__((__packed__))" -Iinc -I `fltk-config --includedir` -g -Wall -g -MD -MP -MF .dep/CGuiWindow.o.d src/CGuiWindow.cpp -o build/CGuiWindow.o I do have -std=c++11 set which might be unusual. Nothing else out of the norm. But I didn't have that set for the "hello world" program that failed.
ChrisArena52 Posted June 23, 2016 Author Posted June 23, 2016 My link line: g++ build/CCircularBuffer.o build/CGuiWindow.o build/CMessageHandler.o build/CSpiMaster.o build/CHoldInterrupts.o \ build/CSpiMessage.o build/CSetPoint.o build/guiMain.o build/MsgQueueType.o build/CVentilatorTestMsg.o build/CVentilatorParmMessages.o \ build/CGpioInputBit.o build/CGpioBit.o build/CPeriodic.o build/COnDemand.o build/CTrigger.o build/FlowDataPointType.o build/crcpy.o \ -L/usr/lib/arm-linux-gnueabihf -lm -lc `fltk-config --ldflags` -lpthread -o guiMain
ChrisArena52 Posted October 6, 2016 Author Posted October 6, 2016 I see this problem WITH the CONFIG_OABI_COMPAT=y. Is this still a problem anyone else is seeing? Thanks!
frix Posted November 5, 2016 Posted November 5, 2016 Good day, I'm developing on the Allwinner A20 & A33 CPUs, which contains ARM cores. I've first noticed the segfault during remote debugging, using gdbserver, from my host PC to the target. Debugging the the application directly on the target did not cause this problem. Performing the remote debugging from a 32-bit host to the 32-bit target made no difference. That seemed to eliminate the possibility of a 64/32 bit compatibility issue. My setup: Host PC: Kubuntu 16.04 64-bit Toolchain: gcc-linaro-6.1.1-2016.08 : gdb version (Linaro_GDB-2016.08) 7.11.1.20160801-git Obtained from: https://releases.linaro.org/components/toolchain/binaries Target: Ubuntu 16.04 ARMHF : GDB version: (Ubuntu 7.11.1-0ubuntu1~16.04) 7.11.1 Illustrating the problem ------------------------------ Program: main.c #include <stdio.h> int main (void) { printf("Hallo world!\n"); return 0; } Compile on host PC: $ arm-linux-gnueabihf-gcc -g main.c -o main_32 File signature: $ file main_32 main_32: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=cc1a4a1ff17da63f9f8362c84dffe54ee7fff4ff, not stripped Remote target: The executable (main_32) needs to be copied to the remote target $ gdbserver :5555 main_32 Process main_32 created; pid = 904 Listening on port 5555 Remote debugging from host 192.168.7.2 Host PC: $ arm-linux-gnueabihf-gdb ./main_32 (gdb) target remote 192.168.7.1:5555 Remote debugging using 192.168.7.1:5555 Reading /lib/ld-linux-armhf.so.3 from remote target... warning: File transfers from remote targets can be slow. Use "set sysroot" to access files locally instead. Reading /lib/ld-linux-armhf.so.3 from remote target... Reading symbols from target:/lib/ld-linux-armhf.so.3...Reading /lib/ld-2.23.so from remote target... Reading /lib/.debug/ld-2.23.so from remote target... (no debugging symbols found)...done. 0xb6fd7a40 in ?? () from target:/lib/ld-linux-armhf.so.3 (gdb) continue Continuing. Program received signal SIGSEGV, Segmentation fault. 0xb6fd9822 in ?? () from target:/lib/ld-linux-armhf.so.3 To try and figure out where the segfault occurred I figured that the debug symbols needed to be loaded. The gdb command 'set debug-file-directory' can be used to accomplish this. It seems that this command is only relative to the host PC filesystem and not according to the remote target file system. With 'set sysroot' the debugger can also be instructed to load all data locally instead of transferring it runtime over the network. I've copied the full contents of the SD card residing on the Allwinner A20 rootfs to a local directory on the host PC: /opt/gnueabihf_rootfs Illustrating the solution ------------------------------- Required packages: apt-get install libc6-dbg Remote target: $ gdbserver :5555 main_32 Process main_32 created; pid = 912 Listening on port 5555 Remote debugging from host 192.168.7.2 Hallo world! Child exited with status 0 Host PC: $ arm-linux-gnueabihf-gdb ./main_32 (gdb) set debug-file-directory /opt/gnueabihf_rootfs/usr/lib/debug (gdb) set sysroot /opt/gnueabihf_rootfs (gdb) target remote 192.168.7.1:5555 Remote debugging using 192.168.7.1:5555 Reading symbols from /opt/gnueabihf_rootfs/lib/ld-linux-armhf.so.3...done. Reading symbols from /opt/gnueabihf_rootfs/usr/lib/debug/lib/arm-linux-gnueabihf/ld-2.23.so...done. 0xb6fd7a40 in _start () (gdb) continue Continuing. Cannot parse expression `.L966 4@r4'. warning: Probes-based dynamic linker interface failed. Reverting to original interface. Even though there is a warning regarding "Probes-based dynamic linker interface failed", the program keeps on running correctly. The thread describing the GDB patch about the linker interface can be read at: https://sourceware.org/ml/gdb-patches/2015-08/msg00629.html It appears the work around was introduced around August 2015, but if you do not specify the path to the debug symbols, the debugger still segfaults. The 'set debug-file-directory' and 'set sysroot' can be added to the .gdbinit file to be applied automatically when you start a remote debug session. Regards, Frikkie Thirion
