What's needed on SD Card after SATA install?
Just a simple little question - I've moved my system to SATA, but there are still full OS on the SD Card:
~# ls /media/mmcboot/
bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  selinux  srv  sys  tmp  usr  var
I would like to remove unused stuff to make some space.
If your ROOTFS is now on SATA, the only thing you need to keep on SD is the /boot and, of-course, the /lost+found, everything else could be deleted ...
