Talkabout Posted December 14, 2019 Posted December 14, 2019 Hi guys, I have recently bought a Rock64 to improve the performance of my VPN gateway. First tests look very promising as you can see here: root@rock64:~# openssl speed -evp aes-128-cbc -elapsed You have chosen to measure elapsed time instead of user CPU time. Doing aes-128-cbc for 3s on 16 size blocks: 15394610 aes-128-cbc's in 2.99s Doing aes-128-cbc for 3s on 64 size blocks: 12591175 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 256 size blocks: 6719021 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 1024 size blocks: 2448108 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 8192 size blocks: 352617 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 16384 size blocks: 177668 aes-128-cbc's in 3.00s OpenSSL 1.1.1d 10 Sep 2019 built on: Sat Oct 12 19:56:43 2019 UTC options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr) compiler: gcc -fPIC -pthread -Wa,--noexecstack -Wall -Wa,--noexecstack -g -O2 -fdebug-prefix-map=/build/openssl-H2OJIf/openssl-1.1.1d=. -fstack-protector-strong -Wformat -Werror=format-security -DOPENSSL_USE_NODELETE -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2 The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 82379.18k 268611.73k 573356.46k 835620.86k 962879.49k 970304.17k root@rock64:~# openvpn --genkey --secret /tmp/secret root@rock64:~# time openvpn --test-crypto --secret /tmp/secret --verb 0 --tun-mtu 20000 --cipher aes-256-cbc Sat Dec 14 10:26:40 2019 disabling NCP mode (--ncp-disable) because not in P2MP client or server mode real 0m4.978s user 0m4.945s sys 0m0.032s Unfortunately when executing a simple curl, the throughput is very low: root@rock64:~# curl -L https://speed.hetzner.de/1GB.bin > /dev/null % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 2 1000M 2 29.9M 0 0 2090k 0 0:08:09 0:00:14 0:07:55 3106k When using Ubuntu 18.04 Bionic I am reaching speeds of 8,4MByte/s. I have checked the openvpn process and it seems that it is only using 25% of CPU, whereas when using in Ubuntu it is using 50-60%. What are the differences here and why is Armbian limiting the process to 25%? Thanks! Bye
dolphs Posted December 15, 2019 Posted December 15, 2019 check 1/ kernel settings, eg: net.core.default_qdisc = fq net.ipv4.tcp_congestion_control = bbr net.core.rmem_max = 16777216 net.core.wmem_max = 16777216 net.ipv4.tcp_rmem = 4096 87380 16777216 net.ipv4.tcp_wmem = 4096 87380 16777216 net.ipv4.tcp_fastopen = 3 net.ipv4.tcp_no_metrics_save = 1 net.ipv4.tcp_slow_start_after_idle = 0 net.ipv4.tcp_timestamps = 0 2/ openvpn settings, eg; sndbuf 393216 rcvbuf 393216 push "sndbuf 393216" push "rcvbuf 393216" comp-lzo no #No need for streaming fast-io #Optimize I/O writes tls-version-min 1.2 remote-cert-tls client cipher AES-128-CBC ncp-disable auth SHA256 auth-nocache both ends have h5 (neo2 lts) currently and get upload/download of >100Mbit over VPN tunnel BTW kernel 5.3.9 shows on this board lower values so you should easily get 100Mbit openssl speed -evp aes-128-cbc -elapsed :~# openssl speed -evp aes-128-cbc -elapsed You have chosen to measure elapsed time instead of user CPU time. Doing aes-128-cbc for 3s on 16 size blocks: 12715522 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 64 size blocks: 10201155 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 256 size blocks: 5342908 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 1024 size blocks: 1919464 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 8192 size blocks: 274635 aes-128-cbc's in 3.00s Doing aes-128-cbc for 3s on 16384 size blocks: 138772 aes-128-cbc's in 3.00s OpenSSL 1.1.1a 20 Nov 2018 built on: Thu Nov 22 18:40:54 2018 UTC options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr) compiler: gcc -fPIC -pthread -Wa,--noexecstack -Wall -Wa,--noexecstack -g -O2 -fdebug-prefix-map=/build/openssl-d3BJKw/openssl-1.1.1a=. -fstack-protector-strong -Wformat -Werror=format-security -DOPENSSL_USE_NODELETE -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2 The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 67816.12k 217624.64k 455928.15k 655177.05k 749936.64k 757880.15k
Talkabout Posted December 24, 2019 Author Posted December 24, 2019 Thank you very much, pointing to the "sndbuf/rcvbuf" values was the key. After changing those the throughput showed "normal" values again. Bye 1
