On a CB1....
cubie@cubieboard:~$ uname -a
Linux cubieboard 4.5.2-sunxi #11 SMP Thu Apr 28 21:53:25 CEST 2016 armv7l GNU/Linux
cubie@cubieboard:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.4 (jessie)
Release: 8.4
Codename: jessie
cubie@cubieboard:~$
... I'm trying to use the gpio pins I set up in script.bin with this configuration:
[gpio_para]
gpio_used = 1
gpio_num  = 4
gpio_pin_1 = port:PG02<1><default><default><default>
gpio_pin_2 = port:PG04<1><default><default><default>
gpio_pin_3 = port:PG06<1><default><default><default>
gpio_pin_4 = port:PG08<1><default><default><default>
No other peripherals are using those pins that are configured in my fex file. A scan of the DTS file also shows nothing using those pins.
When I enable pin 1 via:
cd /sys/class/gpio
echo 1 > export
the gpio1 device shows up.
When I do
cd gpio1
echo "out" > direction
the network interface stops communicating. The system is still alive as I can use a serial session to look at the system, but the networking is gone and I can't restart it. Rebooting is required to get it back.
The same thing happens with my CB2.
What's wrong with what I'm doing? top shows nothing burning cpu cycles.
I need networking. I'm trying to get openocd running in my CB to program my STM32F303 via the SWD protocol.
Thanks!
Chris
You are using mainline kernel where GPIO numbering is different and FEX settings have no effect.
In your case network dies because GPIO 1 maps to PA01, which is used by EMAC core.
Please check this page for pin numbering scheme (section "Accessing the GPIO pins through sysfs with mainline kernel"). For example PG02 will be GPIO 194.
Umm, what from the script.bin file does something? Is anything driven from its contents? Is it in use during ANY part of the system's operation?
If the pin had been assigned a function, how was I able to use it?
Thanks,
Chris
No, with mainline kernel it is not used in any way.
No idea. Assigned =/= locked, so it still may be possible to override this function.
So why is it preserved when not in use? Seems like an excellent misdirection.
I thought when you grabbed a gpio pin that was supposed to be registered somewhere (gpio driver?) so that the kernel had some control over the access.
