I can't connect my orange pi pc to internet from my Pc with ethernet
Hi guys,
I am trying to connect my orangePi internet with ethernet cable but nothing works
I tried every way but still I have no internet So please help me.
Here are the solutions I tried:
1) I open the share settings from Wifi properties and connect the pi to Pc with normal ethernet cable
2)Bridge the ethernet and wifi
3) installed samba in orange pi
and I have nothing
OrangePi's ethernet leds are running but no internet
I have one last solution ,
buying a wifi module and connect to wifi with it but I have no idea about wifi modules.
Sorry for my english.
How did you connect the ethernet cable?
It has to come from your router to the Orange Pi. Not from a pc to the OPi.
If you did this correct, what image are you using on the OPi? What model is your OPi?
My pc connected to Wifi I am trying to share Wifi internet with ethernet cable
I am living in dormitary so I can't  connect the cable to router
I am using armbian and OrangePi PC
The issue is likely the set-up on your PC, not the armbian device.
For your PC to connect a downstream device, it needs to be configured as a router. On Linux devices that means (at least) that the "net.ipv4.ip_forward"  syscontrol is set appropriately.
information here
If your PC is a windows beast, the equivalent info is here, though I suspect that on recent windows, there is an internet sharing set-up that is equivalent, and less intrusive than regedit hacks. Don't have a windows PC to test on, sorry.
Harry
