Sevc Dominik Posted March 9, 2020 Share Posted March 9, 2020 (edited) Armbianmonitor: https://cl1p.net/DzairoOrangePiZero Hi all. I have problem with SPI on my board . I find solution but I want to know why .. On first : Linux orangepizero 5.4.20-sunxi #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020 armv7l armv7l armv7l GNU/Linux If go to armbian-config and enable SpiDev .. then reboot not find SPI device on my dev tree .. if look to armbianEnv.txt there is spi-spidev but on dev tree no SPI device .. My solution is this : on /boot/dtb/overlay is file sun8i-h3-spi-spidev.dtbo , decompile it and there is this text : /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@01c68000"; spi1 = "/soc/spi@01c69000"; }; }; fragment@1 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; spidev { compatible = "spidev"; status = "disabled"; reg = <0>; spi-max-frequency = <1000000>; }; }; }; fragment@2 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; spidev { compatible = "spidev"; status = "disabled"; reg = <0>; spi-max-frequency = <1000000>; }; }; }; }; I don't know why but if change text to this : /dts-v1/; // magic: 0xd00dfeed // totalsize: 0x314 (788) // off_dt_struct: 0x38 // off_dt_strings: 0x2b4 // off_mem_rsvmap: 0x28 // version: 17 // last_comp_version: 16 // boot_cpuid_phys: 0x0 // size_dt_strings: 0x60 // size_dt_struct: 0x27c / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@1c68000"; spi1 = "/soc/spi@1c69000"; }; }; fragment@1 { target = <0xffffffff>; __overlay__ { status = "okay"; #address-cells = <0x00000001>; #size-cells = <0x00000000>; spidev@0 { compatible = "spidev"; reg = <0x00000000>; spi-max-frequency = <0x000f4240>; }; }; }; fragment@2 { target = <0xffffffff>; __overlay__ { status = "okay"; #address-cells = <0x00000001>; #size-cells = <0x00000000>; spidev@0 { compatible = "spidev"; reg = <0x00000000>; spi-max-frequency = <0x000f4240>; }; }; }; __fixups__ { spi0 = "/fragment@1:target:0"; spi1 = "/fragment@2:target:0"; }; }; and recompile then all working .. on my dev tree I see two devices: crw-rw---- 1 root spidev 153, 0 Mar 8 16:55 /dev/spidev0.0 crw-rw---- 1 root spidev 153, 1 Mar 8 16:55 /dev/spidev1.0 I test it on my Osciloscope and see signal , then I connect MISO wit MOSI and make test with spidev-test and work .. now I connect real SPI device (any radio nRF24L01 or similar .. and try real test.. question is why I must do this ??? what is wrong?? best regards.. Edited March 9, 2020 by Sevc Dominik Link to comment Share on other sites More sharing options...
Sevc Dominik Posted March 9, 2020 Author Share Posted March 9, 2020 (edited) On line status = "disabled" change to "okay" and move line to different position then works.. Edited March 9, 2020 by Sevc Dominik Link to comment Share on other sites More sharing options...
Nuha Arina Rafiuddin Posted March 14, 2020 Share Posted March 14, 2020 I think you need to add param_spidev_spi_bus on armbianEnv. allwinner overlay example Link to comment Share on other sites More sharing options...
