that_person Posted June 4, 2016 Posted June 4, 2016 Hi there, I see `iw list` is showing that the i4 pro's internal chip supports AP mode. [1] However, when I try to run `/usr/sbin/hostapd /etc/hostapd.conf` it errors out with no driver entry or driver=nl80211 in hostapd.conf [2] Configuration file: /etc/hostapd.conf Failed to create interface mon.wlan0: -95 (Operation not supported) wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE wlan0: Could not connect to kernel driver Using interface wlan0 with hwaddr 40:2c:f4:ae:16:c6 and ssid "aa" Failed to set beacon parameters wlan0: Could not connect to kernel driver Interface initialization failed wlan0: interface state COUNTRY_UPDATE->DISABLED wlan0: AP-DISABLED wlan0: Unable to setup interface. hostapd_free_hapd_data: Interface wlan0 wasn't started So, seeing that lshw shows the `brcmfmac` driver, I set driver=brcmfmac to be greeted with: Configuration file: /etc/hostapd.conf Line 8: invalid/unknown driver 'brcmfmac' 1 errors found in configuration file '/etc/hostapd.conf' Failed to set up interface with /etc/hostapd.conf Failed to initialize interface I'm currently on 4.5.2-cubox kernel. brcmfmac shows up in lsmod. Anyone figured out how to set up an AP using the internal broadcom chip? I'm at a loss. [1] # iw list Reveal hidden contents Wiphy phy0 max # scan SSIDs: 10 max scan IEs length: 2048 bytes Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Device supports roaming. Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) * CCMP (00-0f-ac:4) * CMAC (00-0f-ac:6) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP Band 1: Capabilities: 0x1020 HT20 Static SM Power Save RX HT20 SGI No RX STBC Max AMSDU length: 3839 bytes DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 16 usec (0x07) HT TX/RX MCS rate indexes supported: 0-7 Bitrates (non-HT): * 1.0 Mbps * 2.0 Mbps (short preamble supported) * 5.5 Mbps (short preamble supported) * 11.0 Mbps (short preamble supported) * 6.0 Mbps * 9.0 Mbps * 12.0 Mbps * 18.0 Mbps * 24.0 Mbps * 36.0 Mbps * 48.0 Mbps * 54.0 Mbps Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (disabled) Supported commands: * new_interface * set_interface * new_key * start_ap * join_ibss * set_pmksa * del_pmksa * flush_pmksa * remain_on_channel * frame * set_channel * start_sched_scan * start_p2p_device * crit_protocol_start * crit_protocol_stop * connect * disconnect Supported TX frame types: * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 Supported RX frame types: * managed: 0x40 0xd0 * P2P-client: 0x40 0xd0 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 * P2P-device: 0x40 0xd0 software interface modes (can always be added): valid interface combinations: * #{ managed } <= 1, #{ AP } <= 1, total <= 2, #channels <= 1 Device supports scan flush. [2] Current hostapd.conf Reveal hidden contents ssid=aa interface=wlan0 hw_mode=g channel=1 driver=nl80211 bridge=br0 logger_syslog=0 logger_syslog_level=0 wmm_enabled=1 ieee80211n=0 wpa=2 preamble=1 wpa_psk=*** wpa_passphrase=*** wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 ignore_broadcast_ssid=1 country_code=LT
