nickbreen Posted March 21, 2020 Posted March 21, 2020 Armbianmonitor: http://ix.io/2eND Re: the built-in 16GB emmc on a 14" pinebook (early model). Applies to Armbian_20.02.1_Pinebook-a64_bionic_current_5.4.20.img and also to trunk build with dev kernel. Prevents installation to emmc from SD, which worked from trunk@3b1418fb5b58f187c658a050c592f2c50fb2db04 in January. I haven't managed to find from which commit it started failing yet. It is in some partial/invalid state in u-boot: => mmc list mmc@1c0f000: 0 (SD) mmc@1c10000: 2 mmc@1c11000: 1 => mmc dev 0 switch to partitions #0, OK mmc0 is current device => mmc info Device: mmc@1c0f000 Manufacturer ID: 1b OEM: 534d Name: 00000 Bus Speed: 50000000 Mode: SD High Speed (50MHz) Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 7.6 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes => mmc dev 1 => mmc info Device: mmc@1c0f000 Manufacturer ID: 1b OEM: 534d Name: 00000 Bus Speed: 50000000 Mode: SD High Speed (50MHz) Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: 7.6 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes => mmc dev 2 Card did not respond to voltage select! It is absent when booted, though has a token line in the log as "mmc1": # dmesg | grep -i mmc [ 2.515757] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 2.541026] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.542017] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq [ 2.560303] mmc0: error -110 whilst initialising SD card [ 2.565772] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.584669] mmc1: new high speed SDIO card at address 0001 [ 2.592188] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 3.645870] mmc0: new high speed SDHC card at address 0001 [ 3.646999] mmcblk0: mmc0:0001 00000 7.61 GiB [ 3.649985] mmcblk0: p1 p2 [ 4.019864] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.389779] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
nickbreen Posted March 21, 2020 Author Posted March 21, 2020 Possibly relevant: https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sunxi/add-nanopi-air-emmc.patch https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sunxi/add-a64-olinuxino-emmc-support.patch https://github.com/ayufan-pine64/boot-tools/commit/d022b303df9a13e2583d3fedc95b35be06731f12
